Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-11-2010, 08:51 AM
jimglass is on a distinguished road
How to pause and resume tool
I have built a wire EDM and would like Mach3 to run the machine.
I need to pause the wire (tool) advance and then resume from and external contact input signal.
Turbocnc does this by hitting the ESC key then Y/N to resume the tool advance. I heard Mach3 could do this from an external contact as an input.
A friend of mine thinks I need to use the THC function.
My wire EDM has a circuit to monitor the spark voltage. When the spark voltage is high the wire can advance. When the spark voltage drops to a preset point the advance needs pause until the spark voltage rises again and the wire advance resumes.
I heard Mach3 could do this.
Jim
www.outbackmachineshop.com
hardeware pause pause detected????? Conquest1224 Commercial CNC Wood Routers 1 05-07-2007 10:06 PM
repost of resume with corrections dpotts Employment Opportunity 0 03-01-2007 09:38 PM
Moving to W. Tennessee (Resume) dpotts Employment Opportunity 0 01-12-2007 06:14 PM
VF-4 Tool changer pause!! ZR Machine Haas Mills 8 11-01-2005 06:52 PM
Here is my Resume, CNC programmer&machinist cnchigh Employment Opportunity 0 06-11-2005 12:16 PM
