| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
Has anyone else had and problems with the single block function in Mach3? I've been having problems with the software jumping lines of code after I take it out of single block mode. This has happened to me twice. |
| Hi, Are you sure the machine actually skips the blocks when this happens and not only the G-code display? I believe there are some syncing issues with the G-code display and I seem to remember this being one of them, the display either jumps the number of lines you have the look ahead set to or to the next M-code in the code, whatever is "closest". The actual machine however should not skip any code. /Henrik. |
| Uuh, ouch...that's not good at all. I haven't had that happen to me but I don't do much cutting these days. I'd recommend you make a post on the forum at Machsupport.com or at the Mach3 Yahoo usergroup. When/if you do try to be as specific as possible, what version of Mach3, are using the LPT-port or an external pulse engine (Smoothstepper for example), what does/did the code look like, on which line did you turn off singled block etc. That will make it easier for other users to try to verify it and for Brian to find it, hopefully. /Henrik. |
| Problem- Okuma LB-15 Sinble blocks in auto / single block off. | mcrosby | Okuma | 3 | 03-23-2009 08:57 AM |
| Need Help!- stuck in single block | Tandem1 | Fanuc | 9 | 02-21-2009 10:04 AM |
| single block switching | colin1544 | AjaxCNC Control Products | 1 | 11-10-2008 10:18 PM |
| Need Help!- Mazak T32 - Single Block - Blinking Light | Artur_Chicago | Mazak, Mitsubishi, Mazatrol | 4 | 09-02-2008 10:09 PM |
| Single Block problems? | mark c | Mach Mill | 1 | 06-15-2008 02:11 PM |
