Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-28-2009, 09:24 AM
Rico55 is on a distinguished road
Unwanted Axis Movement
I have just got my router changed over to Mach3 and Gecko drives, and notice that when I load a g-code program into Mach3, I get a slight movement in one or more axis on the machine. The machine will also start moving contiuously if I minimize Mach3 and try to open another program in Windows. I can avoid this by disabling the charge pump temporarily in Config, but would prefer not to have to do this every time I load a program. I have Mach3 set up on a milling machine with Xylotex drivers, and have never had this problem. What is causing it, and what do I need to do to prevent it?
Old 12-28-2009, 09:36 AM
Crevice Reamer's Avatar
Crevice Reamer is on a distinguished road
Mach3 needs to control the entire computer. You should not even have other applications ON the computer, let alone try to run them while using Mach3.
It's also possible that you are getting crosstalk between your wiring. Is your Home/limit switch wiring shielded?
CR.
http://crevicereamer.com
Too many PMs. Email me to my name plus At A O L dot com.
Old 12-28-2009, 09:38 AM
ger21's Avatar
If Mach'3 isn't telling it to move, and it's moving, then you have an electrical issue. The only way the motors can move is if they are getting step signals. If Mach3 is not sending them, then you must have electrical noise. It's very odd that it happens when you open another program, though. And also that it moves when you load g-code. I don't think this has anything to do with Mach3. You should post this to the Mach support Yahoo group.
Problem- Unwanted axis movement 5th-axis Fadal 2 09-09-2009 11:16 AM
Unwanted axes movement. corrie Controller & Computer Solutions 20 03-15-2009 08:57 PM
Axis Movement KARD CamSoft Products 1 05-21-2008 05:29 AM
Unwanted Z-movement... sweFredrik Machines running Mach Software 2 04-27-2008 05:40 PM
4th axis movement (and a few other gen ?s) corpse General Metal Working Machines 2 08-04-2004 06:13 PM
