Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-21-2009, 01:22 PM
mdclockguy is on a distinguished road
Mach3 & VCarvePro error
Created a simple 1.5 inch circle in vCarvePro5. Getting an error message in Mach3 stating "Radius to end of arc differs from radius to startline 6" tryed using both the generic g-code and Mach3 post processors and get the same error code with just differect line number errors. Do in the same process as a simple 1.5 inch square, no problem. Machine is a K2 KT1425 and controller is a HobbyCNC. Any ideas?
Old 12-21-2009, 03:40 PM
ger21's Avatar
Go to general config in Mach3 and change the IJ mode to incremental.
Old 12-21-2009, 04:49 PM
Barney2wood is on a distinguished road
That did it. Thanks
AlibreCAM and Mach3 K-Word Error cjjonesarmory Mach Mill 1 07-02-2009 12:35 PM
VCarvePro on Gravograph IS400 dgreensill Engraving Machines 4 02-09-2009 08:12 AM
Error in mach3 mill EL34 Mach Mill 8 02-22-2008 10:45 AM
Mach3 Error Message: Zero radius arcLine NickW909 Mach Software (ArtSoft software) 6 02-07-2008 04:54 AM
Mach3 - part error MICHAELT Mach Software (ArtSoft software) 6 07-25-2007 01:19 PM
