Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-21-2009, 07:39 AM
Telly is on a distinguished road
LazyCam Code Posting
Hello,
When I click the Post Code button in LazyCam it says the File Posting complete but my .tap file is not in the C:\Mach3\Gcode folder, as set in the Posting Code Options.
I cannot understand why this is happening, unless its because its a Google Sketchup DXF file.
I have uploaded the DXF and the Lcam file is in the test.zip folder.
Any help would be great thanks!
Old 12-21-2009, 08:10 AM
ger21's Avatar
I don't use LC, but try this file. It's a cleaned up version with all the things LC doesn't like removed.
Old 12-21-2009, 08:11 AM
ger21's Avatar
Also, if you haven't done so, try reading the manual.
http://www.machsupport.com/forum/ind...c,12078.0.html
Old 12-21-2009, 08:14 AM
Tweakie's Avatar
Tweakie is on a distinguished road
If it's any consolation I have just tried this and I can't post the file either.
If you have the time post this one on the Mach forum as well.
Tweakie.
CNC is only limited by our imagination.
Old 12-21-2009, 08:21 AM
Yes the file worked. What did u use to "clean" the DXF?
Old 12-21-2009, 08:51 AM
Tweakie's Avatar
How did you do it please Gerry ?.
I have read the LazyCam manual - can't say I fully understand it all but I would like to know what was wrong with the original file.
Tweakie.
Old 12-21-2009, 09:02 AM
ger21's Avatar
I opened it in AutoCAD and deleted all the 3D stuff. I left the 4 lines that make the border of the part. The 3 circles consisted of 3D polylines. I don't think LazyCAM supports them, so I replaced them with actual circles.
You should be able to do this in any CAD program that'll let you use an isometric view. If you only have a top view, it'd be difficult to select the stuff you don't want.
Old 12-21-2009, 09:10 AM
Ah, I was thinking I would need to import it to AutoCad/Redraw it.
So now I will Draw in Stetchup, import to AutoCad, and use that DXF in LC.
Great, Thank you for the help. Happy Holidays!
Old 12-21-2009, 10:06 AM
ger21's Avatar
Isn't it a lot easier to draw a rectangle and 3 circles in AutoCAD, rather than going through all those steps??
Old 12-21-2009, 10:38 AM
Tweakie's Avatar
Thanks for the explanation Gerry - much appreciated.
Telly, sorry for jumping onto your thread but I just had to know the answer to this one also. (avoiding 3D polylines seems to be the way to go).
Tweakie.
  #11   Ban this user!
Old 12-21-2009, 11:22 AM
Its was part of a CNC machine I made in sketchUp, because i find it easy to use. So that is a part of the CNC front plate.
http://farm5.static.flickr.com/4037/...6e1c0796_o.jpg
If I was making the plate only I would do it in just AutoCad.
Do u know of an good 3D AutoCad Tutorials ?
Thank You Telly!
Old 12-21-2009, 01:09 PM
ger21's Avatar
Thank You Telly!
Ask away and I'll tell you how to do whatever you want. What version of AutoCAD?
Lazycam lead in: How to change code?? skipper LazyCam 5 04-29-2012 12:01 PM
Need Help!- Post G code from lazycam to Mach 3 MotoGems Mach Mill 3 11-07-2009 01:48 PM
Problem- Posting Code southernexplore BobCad-Cam 8 08-16-2009 03:08 PM
Need Help!- Mach 3 LazyCam G Code geoff3881 Mach Software (ArtSoft software) 2 09-09-2008 01:47 PM
?? about posting code in v22 JDsto BobCad-Cam 5 01-13-2008 11:34 AM
