Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-17-2009, 07:33 AM
u77171 is on a distinguished road
Mach3 offset issue
I have been using Mach3 for a while now with no issues until now. I did something that gave my Z axis a 1" offset. If I want to plunge 1/2" I have to program it (G code) to plunge 1.5"?? If I don't do that i'll only cut air. Can anybody help me with this problem?
Old 12-17-2009, 10:12 AM
ger21's Avatar
Check your steps/unit in motor tuning.
Old 12-17-2009, 11:27 AM
M250cnc's Avatar
M250cnc is on a distinguished road
Check the offset page to make sure you are in G54 mode.
Check to tool table to make sure you haven't got an offset on the tool number your using.
HTH
Old 12-18-2009, 11:44 AM
Thanks for the help guys, I appreciate it. I'm pretty sure the steps/units is OK since if I jog the axis 1", for example, it moves an inch and the Z axis position indicator shows an inch. I'll check out the offset page and tool table.
Old 12-18-2009, 11:50 AM
ger21's Avatar
Is there a G43 tool length offset in your code?
Fanuc 16i variable offset issue PCCDon Fanuc 3 11-26-2009 01:04 AM
Mach3 scale issue Chris64 Mach Software (ArtSoft software) 3 10-18-2009 09:30 PM
Issue with work offset not comming from machine zero. Hermle UWF851 Fanuc 11 06-17-2009 03:41 PM
Eagle CAM Processor output - Mach3 Size issue deleteallusers G-Code Programing 7 05-02-2007 09:14 AM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
