Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 11-01-2009, 02:39 PM
richbads is on a distinguished road
MACH 3 & 4 axis foam cutter
Hello,
I've setup my 4 axis foam cutter to run through Mach3, all works ok when in jog mode & running a demo cut file, if you hit move to zero X,Y & A axis go to zero but Z stays put or goes to safe "Z" until the other three are at zero then this moves to zero. What's worrying me is if you have to stop the machine & go to zero all the other axis return then z starts it's move after the other have reached zero.
I understand when using a router that goes to a safe height until everything is at zero to prevent gouging & tool breakages.
How do I configure X & Z axis to go to a safe height before moving to zero
Old 11-06-2009, 01:30 AM
ktb100's Avatar
ktb100 is on a distinguished road
Hi Richbags,
You can configure which axis moves first or what you want each one to do by:
1) While viewing the program page - Click on "operator" (on the top)
2) Click on "edit button script"
3) Click on the button you want to change ie Ref all home
4) This is the order of what all is done for homing.
5) Edit it as you like and be sure to save it.
Button numbers and OEM button descriptions can be found at:
http://machsupport.com/MachCustomize...itle=Main_Page
Scroll down to #9 for buttons, OEM buttons, DRO's etc.
Hope this helps
Kirk
Using Mach3 with a 4 axis foam cutter richbads CNC Wire Foam Cutter Machines 2 10-28-2009 06:27 PM
Hot Pin Foam Cutter damae CNC Wire Foam Cutter Machines 3 01-24-2009 07:40 PM
Mach3 R3.00 Mill 4 axis Foam cutter setup Andy Smith Mach Mill 1 01-25-2008 07:19 AM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
MS Excel 4 Axis CNC Foam Cutter Experiment arman Foam Cutting Software 5 10-25-2006 03:04 AM
