Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 10-10-2009, 08:11 PM
mkc2's Avatar
mkc2 is on a distinguished road
Mach go to zero
When i set y0.0 x0.0 z0.0 and regen then hit go to zero button to check if the end mill is in the right spot, the z goes down first followed by y & x,
This is not good as it drags across the job and hits clamps.
How do i make z go down last.
any help would be appreciated
thanks michael.
Old 10-10-2009, 09:31 PM
ger21's Avatar
Turn on Safe Z. Config>Safe Z
Old 10-11-2009, 04:18 AM
mkc2's Avatar
Thanks Gerry
will set safe z up.
michael
Newbie- Configuration Mach 2 to Mach 3 cnc-mike Machines running Mach Software 4 11-05-2008 07:43 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Mach 3 no spindle - but OK in Mach 2 zcases Mach Software (ArtSoft software) 9 07-31-2006 07:38 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
