Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 10-10-2009, 03:45 PM
Jamy is on a distinguished road
Mach 3 Manual spindle on.
How comes the spindle on button on Mach 3 software does not turn on he spindle? If the reset button is pressed after the Spindle on then it turns on. Is it because the control logic is inverted? How do you make the spindel to turn on when pressed?
Old 10-10-2009, 03:49 PM
ger21's Avatar
Is the reset flashing when you try to turn it on?
Old 10-10-2009, 03:54 PM
Yes it does
Old 10-10-2009, 04:19 PM
I believe it comes on when you press the on button. Then when you press the reset button it clears and spindle starts.
Old 10-10-2009, 06:39 PM
ger21's Avatar
You can't start the spindle with the reset light flashing, as Mach3 is in E-Stop until you reset.
Need Help!- Need DC spindle manual Captainjack Fanuc 2 09-27-2009 11:31 AM
Mach 3 manual height adjust The_Fixer CNC Plasma and Waterjet Machines 2 06-14-2009 01:15 PM
Spindle Manual Mode Mechamatic Tormach PCNC 9 09-18-2008 12:52 PM
Problem- No Manual Control in Mach 3 AJA General CNC (Mill and Lathe) Control Software (NC) 3 08-05-2008 11:14 AM
Problem- No Manual Control In Mach 3 AJA Mach Mill 0 08-04-2008 07:27 PM
