Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-12-2009, 03:09 PM
rrrevels is on a distinguished road
Jog increment and continous/step
I have been using version 1.84 of Mach3 and recently changed to 3.042. I haven't found the buttons for setting the jog step increment or the button to change from step to continuous movement. I realize that the control and alt j keys will make the changes but how can I tell what the increment is? I used to find that on the Diagnostic tab.
TIA,
Russ
Old 08-12-2009, 03:17 PM
LeeWay's Avatar
LeeWay is on a distinguished road
I think you can hit the tab key and see a flyout pendant. Then when done, hit the tab key again and it will get outta there.
Lee
Old 08-12-2009, 03:24 PM
Thanks Lee,
I will give that a try when I get home this afternoon.
Russ
Old 08-12-2009, 08:09 PM
Thanks again Lee,
That is what I have looking for.
Russ
Need Help!- How do I increment step in one direction? gurvy Mach Software (ArtSoft software) 7 10-21-2008 05:48 AM
Newbie- increment input z axis hrlywomn Mazak, Mitsubishi, Mazatrol 6 03-22-2008 04:00 PM
How to increment a parameter in G-code Involute Syil Products 3 09-22-2007 12:59 AM
Jog Increment gleas Larken 1 07-24-2007 12:07 AM
Increment the Z. civilseal Machines running Mach Software 6 03-06-2007 08:46 PM
