Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-06-2009, 08:30 AM
oldskimmer is on a distinguished road
Smile Mach 3 shutoff
I built cnc router, with Mach 3 controller. Have everything working well with no problems. I leave it unattended at warehouse shop. Would like to get a signal from the system at the end of G code and cutter return to start position and shut down all 110 volt power to router, vacuum etc.
Old 08-06-2009, 09:03 AM
Al_The_Man's Avatar
One way I would think is to assign an M code to an output controlled relay that cuts the coil power to the power device relays.
You would need an M code to reset it at the beginning of a program.
Possibly M3/M5 if not used at present.
Old 08-06-2009, 10:21 AM
ger21's Avatar
Use M3/M5 for the spindle, and another for the vacuum. You can use the coolant codes (M7/M8, M9), or create you're own to turn on and off relays.
Old 08-06-2009, 10:44 AM
Talking
Thanks. I will persue the M code method.
Old 08-06-2009, 10:44 PM
TOTALLYRC is on a distinguished road
End of job stuff
On my router I use mo3/5 for the spindle and use m07/8/9 for the vacuum and other accesroies.
I use a g28 at the end of the code to put the machine back in the home position in case I need to change tools or check there condition.
Old 08-09-2009, 09:04 PM
More help?
Thanks for everyone's help. I build a heck of a machine, but sure do need help to configure mach3. Installed relays for router & vacuum from breakout board but need help to configure it all. Would like to use M3 to turn spindle on, M5,7,8 or 9 to to turn vacuum on and another to turn both off. Should be easy enough to add to program codes at beginning & end, but I'm lost to configure which outputs to what on what configure screen. Breakout board, stepper controls and 3 relay board are all Probotix. Pardon my electronic ignorance but any help is appreciated.
Bob the machinist
Old 08-09-2009, 09:28 PM
ger21's Avatar
M5 turns off M3 and M4. M9 turns off M7 and M8.
So, turn on the spindle with M3, and off with M5.
Turn on vac with M7 or M8 and turn it off with M9.
In Ports and Pins, Outputs, assign one output for router and one for vac (Use outputs 1-6). Then, go to Spindle tab, and assign the router output to the spindle (M3) and the vac output to Mist or Flood (M7 or M8).
Old 08-09-2009, 10:17 PM
Many thanks Gerry. Just the info I need.
Bob
why auto shutoff? spock Sharp CNC 2 01-27-2008 09:43 AM
Can an ejector pin sit against a shutoff surface. DomB Moldmaking 25 04-13-2007 07:01 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
