Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-31-2009, 08:47 AM
bradyaero is on a distinguished road
Ref All Home with Auto Z can it be done?
I'd sure like to be able to combine my Ref All Home with the Auto-Zero tool function for the z axis. Has anyone done this yet?
When the Ref All Home button was pressed, the vb script would do the X, Y home and then execute the auto-zero code. (mach 3 blue) which would touch the bit to the zero plate (mine is built into my table) and then I'd be ready for a job!
The current Ref All Home button contains a script that calls
DoButton (24)
DoButton (23)
DoButton (22)
DoButton (25)
I can't seem to find out what those buttons are.
Thanks, Greg
Old 07-31-2009, 10:22 AM
ger21's Avatar
DoButton (24) = Home Z
DoButton (23) = Home Y
DoButton (22) = Home X
DoButton (25) = Home A
All you'd need to do after this is move into the correct position and run the AutoZero.
Just add the code for those after the above.
Newbie- Part Home vs. Machine Home Mihelich G-Code Programing 6 06-07-2009 01:56 PM
auto set z Ed Williams Mach Mill 1 04-10-2009 08:13 AM
Need Help!- Home again Home again Jiggety Jig. Well Not Just Yet! Mr.Chips DIY-CNC Router Table Machines 10 03-18-2008 08:58 PM
Auto Tool Zero Moondog Machines running Mach Software 13 12-22-2006 06:02 PM
Dx-32 auto N number for you jtree83 Bridgeport and Hardinge Mills 4 09-26-2005 01:28 PM
