Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-21-2009, 05:06 PM
Richotech is on a distinguished road
Z-axis setup/control in Mach3
Hello,
I have made my own 3-axis engraving machine from scratch and have everything running well, but I need help with the Z-axis setup. I have only used the ports/pins and the homing/limits to set the direction and homing. I want to set z-axis home to the up position but the co-ordinates are working in reverse. How do I setup the z-axis ?.
Cheers,
Brett.
Old 07-21-2009, 08:02 PM
ger21's Avatar
Do you want to reverse the direction it's moving? If so, check "Reverse" in the Homing/Limits page.
Old 07-21-2009, 08:21 PM
Hi Gerry,
Zeroing the z-axis to the bottom switch would seem the way to go, but when I have a tool in the spindle it will hit the machine table before the bottom limit switch !. My problem is more about how the z-axis needs to be setup more than how to reverse settings.
Cheers,
Brett.
Old 07-21-2009, 08:50 PM
ger21's Avatar
Typically you home the Z to the top of it's travel, and zero it to the surface of the part before running your programs. You might want to look into making an Auto Zero device.
http://www.cnczone.com/forums/showthread.php?t=36099
Need Help!- Mach3 A axis (4th axis) setup? cadcamslawek Mach Software (ArtSoft software) 10 01-17-2012 08:23 PM
Mach3 R3.00 Mill 4 axis Foam cutter setup Andy Smith Mach Mill 1 01-25-2008 07:19 AM
Featurecam Lathe Setup X axis MAch3 whiteriver FeatureCAM CAD/CAM 0 02-20-2006 05:04 PM
