Can anyone post the wiring diagram for interfacing mach3 with Mitsubishi MR 40 drives. I have connected and tried and tested in as many ways I can. Help me rectify this problem.
I've got 4 J2S-40A drives and have the manual. Where exactly is the error? Which pin is step and which one is direction?
@macona Sir, can you help me how to wire the Mitsubishi servo motors with mach3? I have given the step and direction signals to the drives for pins 23 and 25 on the drive as they are the step and dir pins. And applied 24V DC to the OPC pin.Connected the SG pin the mach bob ground. Set the parameter 21 to 0011 and 0001. But it didnt work.
