Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 06-30-2009, 07:20 AM
wjfiles is on a distinguished road
Question Cutting Dimension problem
I have a problem with cutting to size.
I have steppers, and have set the steps so that in the MDI mode I tell it to move any amount in both X & Y axis the amount of movement is exact.
I cut circles they are perfectly round.
When I cut any of the shapes from the NFS wizards or any toolpath for that matter all the shapes are .63mm under size regardless of the cutter size selected or the size of the shape.
I can work around this by editing the tool and increasing the size of the nominated tool by .63mm.
What is going on here, any Ideas.
WJF
The More I Learn The Less I Seem To Know
Old 02-04-2010, 11:50 PM
Robski is on a distinguished road
Are your settings in ports & pins - mill options correct?
Old 02-06-2010, 11:09 PM
15mgtar is on a distinguished road
I have the same exact problem anyone knows what could cause this ?
Old 02-10-2010, 12:42 PM
have you solved your problem yet wjfiles?
please someone help to solve this problem
Old 02-20-2010, 06:13 PM
zeeway is on a distinguished road
Do you have a tool offset loaded that may be affecting your cutter path?
xy cutting problem melzer Fadal 17 08-25-2010 08:27 AM
Help - Problem cutting with a PLS3.60 Ideas L Laser Engraving & Cutting Machines 8 12-02-2008 08:34 AM
Newbie- Thread cutting problem wab0372 Hand Tooling 4 07-21-2008 11:20 PM
Groove Cutting Problem pprichard General Metalwork Discussion 2 01-18-2006 08:53 AM
Problem cutting arc with lathe. mudwhump G-Code Programing 9 05-23-2004 12:19 PM
