Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 06-04-2009, 10:01 AM
jelwaan is on a distinguished road
convert to DSPMC/IP & mach3
I have an old flame cutting machine ( 2 axis - BLDC motors ), this machine is controlled with an old controller , It is used to cut steel palns.
I want to replace this old controller with a new Computer based controller, and I found the DSPMC/IP controller sutable since it can controlled through the ethernet ( the machine is 2m * 8m and I want to controll it from the upper floor).
I want to Interface this controller to the motors, and need help :
what kind of encoders to use with this DC motor, Or I can control them with out encoder (I have two tachoMeters)?
I have made a PWM DC Driver befor, Can I use it to control this motors through DSPMC/IP or I should buy a specific Driver?
Can I use EMC2 to control the DSPMC/IP Or I should use Mach3?
What model of DSPMC/IP I should use to control just two DC motors?
Build Thread- Tsugami spl cnc conversion using DSPMC/ip controller TOTALLYRC Vertical Mill, Lathe Project Log 29 09-11-2010 08:14 PM
Build Thread- BTC-1 retro fit using DSPMC/IP controller. TOTALLYRC Bridgeport and Hardinge Mills 76 06-06-2010 07:50 AM
Need Help!- Import/Convert DXF or PLT files to Mach3.... Mikael Mach Mill 3 12-25-2008 03:33 AM
Convert from JPG to DXF chakaloso General Metal Working Machines 4 03-10-2007 02:31 AM
How did you convert CNCadmin Benchtop Machines 5 03-18-2003 09:42 AM
