| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
| No, they won't work. If you need a parallel port, add a PCI parallel port card. If you want to run Mach3 with a USB connection, you'll need to get a Smoothstepper. www.warp9td.com
| I wondered if it possible to use an usb cable and second db25 breakout board to be able to activate some solid state relays in Mach3, where timing isn't a issue? If not possible, will the serial port hooked up with a db9 breakout board do the job? Thanks in advance, Brian |
| Mach does not use the USB port, unless a plugin is written for a USB Device. There are several different options for IO on Mach3 other than the parallel port. There is the Pokeys USB device. Mach3 also supports Modbus through the serial port. The ModIO is one supported device. CNC4PC also offers several Modbus Devices
| parallel port or parallel universe | bruno34 | Taig Mills & Lathes | 5 | 04-15-2009 10:58 AM |
| parallel port | wantsout | General Electronics Discussion | 15 | 09-23-2008 11:49 PM |
| parallel cable pins | nicanor76 | DIY-CNC Router Table Machines | 8 | 05-14-2008 06:01 PM |
| anyone tried USB to Parallel cable? | nicanor76 | DIY-CNC Router Table Machines | 5 | 05-11-2008 07:09 PM |
| Parallel Cable Length | Cartierusm | Mach Software (ArtSoft software) | 2 | 09-11-2007 11:53 PM |
