Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 04-19-2009, 04:57 PM
box1sa is on a distinguished road
Post Mach 3 on Isel Build
I have a router with a isel Controller C142-4 running of my Com port and my spindle of a AD/DA lpt card.
Can Mach be used on this configuration.
I dont seem to be able to get it to work.
Andrew
Old 06-01-2009, 06:04 AM
ktb100's Avatar
ktb100 is on a distinguished road
Hi Andrew,
In case you didn't already have this - here it is.
http://www.isel-germany.de/products/...lang=en&ID=p66
I glanced at it and did not see an analog output. If you have a single speed motor then just use one of the relay outputs. That is the only option I can see but on the web page it gives support phone numbers...
Good luck,
Kirk
Old 06-02-2009, 11:15 AM
Pplug's Avatar
Pplug is on a distinguished road
I know for sure you will not be able to get the controller to work with mach. However, call techno and they can get you the G-code interface that will work with the controller. Also there is a piece of french software called Galaad and Kay that I think will drive the router better than techno isel's own interface. http://www.galaad.net/home-eng.html
Newbie- Isel Automation tgregoire Controller & Computer Solutions 9 11-26-2011 12:30 PM
Need Help!- Isel CNC Router wright Commercial CNC Wood Routers 1 12-18-2008 12:22 PM
Techno Isel wood_donkey Commercial CNC Wood Routers 2 04-19-2007 06:13 PM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Techo-Isel mtuckf CNC Machining Centers 5 06-20-2004 02:41 PM
