Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 04-14-2009, 11:15 PM
ellard is on a distinguished road
Angry mach 3 problem
Hi all I am new the cnc thing and am having a problem brining in my dxf files .I just built a 4x8 CamCutcnc table and the control program is mach 3 when i bring in the dxf file it cuts the outside first. Any help would be greatly appreciated thanks.
Old 04-15-2009, 12:52 AM
TOTALLYRC is on a distinguished road
Hi ellard, how are you generating the g-code from the dxf?
Mike
Old 04-15-2009, 02:36 PM
mach 3 problem
I just bring the file in under the export then it walks thru like 4 steps and generates the gcode
Old 04-15-2009, 03:11 PM
LaserImage is on a distinguished road
What program are you doing that in? Not Mach, it only opens gcode files, not dxf
Old 04-15-2009, 06:53 PM
ger21's Avatar
Assuming your using an older version of Mach3 with the .dxf importer, the order of cut is usually the order that the lines were drawn in the CAD program. Since Mach hasn't had that importer for at least 2 years, I really can't remember much about it.
Your best option would be to buy a CAM program, like SheetCAM or Vectric's Cut2D, which would give you much more control.
mach 3 problem ellard Canadian Club House 1 04-15-2009 12:01 AM
little problem with mach or something else? ataxy Mach Mill 2 01-30-2008 07:27 AM
Anybody had this problem in Mach 3? pointcloud Mach Mill 3 07-13-2007 08:09 AM
Jog problem with Mach 2 jtriggs Mach Mill 0 06-15-2006 12:48 AM
mach 2 problem CNCadmin Mach Software (ArtSoft software) 5 01-16-2005 02:12 PM
