Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 03-28-2009, 09:44 AM
SPEEDRE is on a distinguished road
Perplexing Issue
I have had this problem recently. I made tool paths using V Carve V4.6 , for a part I needed, then ran a dry run to see if the setup was correct. Well it was OK and ran well. The next day I wanted to actually cut the parts out and it was different. What I mean is, It cut one perfect, then, as it began to cut the second ,it went astray. It began the cut about 1.00" offset right over the first part, not at position two, where it was the night before. How does the program change like that ,in less than twenty four hours?. I did not, shut down my computer or make any changes, to the path codes. How can it change overnight. Has this happened to you???? What , if anything ,happened that you can explain to me.!!!!! I have always believed I have Mach 3 set up correct and V Carve is not corrupted......
Old 03-30-2009, 05:28 PM
steve323 is on a distinguished road
Sounds like your steppers skipped a few steps. Mach3 accelerates steppers using a few slow steps before ramping up to full speed steps. If steppers stall during the full speed portion, they often stay stalled for the rest of the move. They recover during the next move, but they may be inches away from where they need to be.
Try slowing down your max speed. On my machine, it also means that it is time to lube the rails and screws.
Steve
Old 04-04-2009, 10:15 AM
Thank you steve323. I think ger21 has a good possible reason for my issue. Check out the thread with virus warning in it. There may be something there for all of us.
Perplexing Problem bohica Mach Mill 2 02-17-2009 08:21 AM
New to CNC, G52 issue andywids G-Code Programing 14 01-10-2009 12:09 PM
Issue at low power.... WilliamD Laser Engraving & Cutting Machines 2 12-01-2006 11:44 PM
Help with selector switch wiring issue (***actually a motor issue***) BEDFORD Industrial Hobbies (Support forum) 7 04-07-2006 03:19 PM
THC Issue Aldoseri CamSoft Products 3 01-31-2006 04:33 AM
