Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-21-2009, 04:43 PM
chaz6966 is on a distinguished road
retrofit on a cinci arrow 750 vmc.
would mach 3 work on a retrofit for a old cincinati vertical machining center.
with a 21 station tool changer. and only 3 axis plus a forth rotaty..
it has the option now but i dont have the rotary table now anyway.
the head moves up and down to change tools.
Old 02-21-2009, 06:46 PM
kcho is on a distinguished road
You must put a CNC. It´s an interesting machine. If you can uses the servo system you only have to buy the CNC. your best choice is A fagor 8035 for three axis, or 8055-8040 for four axis.
Carlos
Old 02-25-2009, 11:01 PM
PoppaBear10's Avatar
PoppaBear10 is on a distinguished road
Mach3 will work on that machine just fine, and at 1/10th the cost of a fagor.
Check the mach support site www.machsupport.com, look under Forums, then look under User machines. You will see 100s of pics and videos of Mills with ATCs axis may be 3,4,5 or even six on some of the BIG planers with W knees. There are vids of Lathes running anywhere from 2-5 axis with ATCs. Plug many many more machines. You can drive Highend Drives with External motion cards if you want as well, like Galil for Analog drives, and Smooth Stepper for Step and Dir drives. Plus you have Absoulte control over the customization of mach3, for Screens, Soft PLC (Brians), Wizards, Plugins, Custom Macros, a modbus in where you can control intellegent IO upto 2048 on TCP and 256 on Serial.........
There is not a control on the market ANYWHERE that gives the users the kind of customizing power that Mach3 does......
Scott
Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
mach 3 software/retrofit arrow 750 chaz6966 Cincinnati CNC 1 06-19-2009 11:04 PM
Need Help!- retrofit to a cinci arrow 750 machining cntr. chaz6966 Mach Mill 0 02-21-2009 04:33 PM
Newbie- Sieg X1 retrofit with Linux EMC2, CNC Fusion retrofit kit and Gecko G540 GreenLead Benchtop Machines 31 11-26-2008 11:55 PM
Cinci Arrow 500 Clawsie Machine General Metal Working Machines 1 06-09-2008 04:48 AM
How can I DNC to Cinci Arrow 500 Clawsie Machine Mastercam 0 11-20-2007 07:36 AM
