Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-11-2009, 06:00 PM
terrysn is on a distinguished road
Question mach mill for 3 axis grinder?
Has anyone applied this to control to a cnc surface grinder? I have a 91 harig 3 axis cnc, with a unison dedtru centerless attachment that could use a new pc based control. The current control is also pc based, but has never worked right. The machine only has about 100 hrs on it so it seems like a good candidate. If you're really curious look at the you tube video's on tru tech grinders to get an idea. They currently own the harig surface grinder name.
All input appreciated,
Thanks,
Terry
Old 02-11-2009, 11:32 PM
neilw20's Avatar
neilw20 is on a distinguished road
Talking Mach3 for grinding
I use Mach3 for CNC grinding.
Main thing is for you to ensure that Mach3 can interface with your hardware.
Look at Mach3 manual for starters.
Writing a simple subroutine is easy and then call it multiple times using say L20 to loop 20 times, having the called program increment say the Z value or move across. I have done rotary stuff with 4th axis also.
Surface Grinding - CNCzone.com-The Ultimate Machinist Community
My Endmill Grinding
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 02-12-2009, 09:53 AM
Thanks Neil,
I'll do some research on my hardware. The video's were great!
Terry
5 Axis Mill Sreen set for Mach 3 PoppaBear10 Screen Layouts, Post Processors & Misc 10 03-12-2009 11:16 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Jig grinder for knee mill cbass Knee Vertical Mills 4 12-04-2005 01:55 AM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
Retrofit: Central Mach. CNC 3 axis Mill Rekd General Metal Working Machines 6 02-06-2004 04:19 PM
