| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
| When I run the driver test it always starts at 25 Mhz, when I change it to say 100 Mhz it stays that way for the duration of the test. If I come back into the test it is again at 25 Mhz. Is there a way to keep it at 100 Mhz? Pat |
| I don;t think there's a way to change it. Why do you need 100Khz? The general rule is to use the slowest Kernel Speed you need.
| The problem I ran into was the "bar" did not "green up" unless I went to 100KHz. The other problem I had was that when I would hit the tab button to jump into the jog screen the pgdn/up and left/right arrows would not jog the axis. I was just playing with the program. Nothing is hooked up. I had the same experience on the desktop that my Hurco is attached to. There I was just trying to get the things to move on the screen, not the machine. Pat |
| Question on test/tuning motors ? | KEYTEEM | Servo Drives | 1 | 04-10-2009 06:27 AM |
| Driver test pulse variations. Are they to large? | jaru-eri | Mach Mill | 10 | 02-25-2008 06:23 PM |
| Problem- Driver test problem... | jaru-eri | Mach Software (ArtSoft software) | 0 | 02-19-2008 05:38 PM |
| Test steppers with driver only? | monte55 | Xylotex | 0 | 10-19-2006 06:55 PM |
| Mach Driver test => Max 23,800Hz | haysys | Mach Software (ArtSoft software) | 3 | 12-18-2005 01:12 PM |
