Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 01-10-2009, 05:10 PM
felixthecat728 is on a distinguished road
Talking Budget CNC Router
How fast can a 7/16" alltread, used as linear drive, go in terms of "ipm"???
Scrap aluminum plates that I got from work: $0
1"x2" and 2"x2" tubing: $50
Harware: $75
Controller, Drivers and motors: $350
A headache and loss of hair for setting up the cnc: priceless
How costly is your router???
Old 01-11-2009, 06:48 AM
neilw20's Avatar
neilw20 is on a distinguished road
100 ipm.
If you want 100ipm with 14tpi that's 1400 RPM
Anything over more than a foot long at that speed will start to whip.
3/4" UNC is still not too big and is 10TPI
For 100ipm you would need 1000 RPM
Is your target lots of seek speed? Do you intend cutting lots of air?
If you are using a 10000 RPM cutter, then that feed might be reasonable.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 01-11-2009, 11:43 AM
Well, basically I built my first Low budget desktop-type CNC router (I mean, a CNC Dewalt 660k cutting tool) based on a 14 tpi alltread as drivetrain and I don't think it goes any faster than 70 ipm using its current motors (60 oz-in). I'm waiting to receive 200 oz-in motors to see if I can push jog speed a little more.
Y axis travel = 14"
X axis travel = 16"
Z axis travel = 4"
Old 01-11-2009, 02:08 PM
ger21's Avatar
70 ipm with allthread and 60oz motors is pretty impressive. I wouldn't think it'd go much faster with bigger motors, unless you running at a very high voltage.
really budget first cnc jwest DIY-CNC Router Table Machines 2 10-29-2008 10:05 AM
Seeking design budget ideas for a large accurate CNC Router. moseus DIY-CNC Router Table Machines 13 12-31-2007 07:06 PM
CNC DIY router on a $1000 budget? dankjones DIY-CNC Router Table Machines 8 07-28-2007 05:23 PM
Budget CNC Router Blackhawk DIY-CNC Router Table Machines 24 02-21-2004 07:19 PM
Cad Cut Cnc Router Plans On A Budget ???? jsatter DIY-CNC Router Table Machines 1 11-27-2003 06:17 AM
