Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: Direction output inverted in Mach3 R3.041
    Aug 2006
    Hello;
    I found out there is a discrepancy between the Mach3 configuration and the pin logic output for the four axes Direction signals, Step pulses are OK. If I setup Direction Active High, the Direction pin, when going forward, goes to zero instead of logic 1.
    Is it something common for all Mach3 revisions or is is something specific to my PC or configuration? Please, I need to find out as soon as possible.
    I would like another user to test it with a multimeter or logic probe, please.
    Best regards,
    Kreutz.
    Aug 2006
    Quote Originally Posted by kreutz View Post
    Kreutz.
    The newer version R3.042 has the same problem.
    Mar 2003
    Shelby Twp, MI....USA
    Under Config > Homing/Limits, do you have "reversed" checked for any axis? That's how you change the motor direction if it's opposite of what's expected.
    Aug 2006
    Quote Originally Posted by ger21 View Post
    Hello Gerry;
    No, nothing is checked, should I check the "reverse" then? I found the problem when testing my new bipolar drives, they use the direction signal also in automatic Slow/fast decay mode circuit. The drives are configured for Active high Step and direction signals but Mach3 was sending the wrong logic level with active high direction, which made the motors to turn in the wrong direction.
    I could easily solve the problem by swapping the A and B motor coils, but then the labeling on my drives is not going to be consistent with the stepper motor wire's color code if people are using Mach3.
    Thanks,
    Kreutz
    Mar 2003
    If you check "reverse", you should get the results your looking for.
    Aug 2006
    Thank You!!
    Best regards,
    Kreutz.
    Oct 2009
    Phil
    Take a look at mine...
    Hi,mine doesn't have any problem at all regarding that matter.
    My machine runs smoothly on the X,Y and Z axes.
    Problem is, Mach3 reads the Gcode correctly but the result is inverted.
    I already fixed it in Artcam by setting the 'mirror' option but i am not yet satisfied.
    Where did i go wrong?
    Oct 2007
    England
    hug bear,
    Check X axis scale, if it = -1.0000 then the axis will mirror movement on X, needs to be +1.0000.
    May 2010
    Incredible! I've had this same problem for awhile and have never even noticed the "scale" setting to the right of the axis readouts on the main panel. I've also been mirroring my patterns to get them to machine correctly. Thanks for the tip!
    Mar 2003
    You guys have your machines set up backwards.
    Oct 2009
    Phil
    Hi
    This is a picture of what i'm seeing right now.
    bbc is the settings before cut and bbcouput is the cut result.
    Where do i set the scale settings?
    I seem to have a hard time finding it.
    Attached Thumbnails Attached Thumbnails Direction output inverted in Mach3 R3.041-bbc.jpg   Direction output inverted in Mach3 R3.041-bbcoutput.jpg
    May 2010
    look to the right of the position numbers for the X, Y, and Z axis. See the scale number 1.0000. Click on it and type -1.0000 and hit enter.
  • Page 1 of 2 12 LastLast
    1. Which Rhino output for Mach3 mill?
      By BEIGeorge in forum Machines running Mach Software
      Last Post: 01-11-2008, 04:47 PM
    2. A3977/Mach3 Direction changes randomly
      By kiltjim in forum Open Source Controller Boards
      Last Post: 12-08-2007, 09:04 PM
    3. Eagle CAM Processor output - Mach3 Size issue
      By deleteallusers in forum G-Code Programing
      Last Post: 05-02-2007, 10:14 AM
    4. Help needed to customize output of Mach3
      By frenzal in forum Screen Layouts, Post Processors & Misc
      Last Post: 10-15-2006, 09:25 PM
    5. Other controllers that output step/direction?
      By cn00728 in forum General Electronics Discussion
      Last Post: 02-02-2005, 02:30 PM
