Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 11-17-2008, 10:57 AM
mgb1974 is on a distinguished road
CNC conversion to Mach Control
We have a older CNC Bed mill. It is some sort of company retrofit. It is called Racer Tech.
Anyway we have found that the software on the machine is limited. It is dos format(which is ok) and it wont move 3 axis at once. It is also very basic from a control standpoint. Hard to edit programs on the control and such.
My questions is has anybody changed a CNC machine to Mach software? How hard was it? Any problems? Advice?
Old 11-17-2008, 04:20 PM
123CNC is on a distinguished road
That CAT has been skinned
Retrofitting a CNC to MACH3 control has been done many times.
To better assess your path forward, you need to inventory your current system. Get and record the various info.
Axis motor info
stepper or servo
rated voltage amps
torque (holding, peak, continuos)
frame/mount size (if replacing)
shaft size & lenght, dual for encoder, dimensions of encoder shaft (if replacing)
Amp/driver info
control signal
+ 10 Vdc
dir +10 Vdc
dir & step
Rated voltage and amps
Armed with this information you can start searching and reading threads and start choosing a path.
If considering MACH3 also consider EMC2.
If you are looking for more turnkey or packaged kits, maybe look at Centroid, Ajax, or Camsoft.
Your journey begins.
Old 12-04-2008, 02:26 PM
Thanks for the response.
What replaces the drivers for the servos?
If I understand this correctly. Mach software is the control portion but what is needed to give feedback to the servos. Basically what I am trying to do is go from a 2.5axis machine to a full 3 axis machine. The software on the machine now will not make a x y and z move at the same time(ex N45 G01 X.0 Y5.3 Z 3.5)
Any insight?? Very much a newbie on what I need.
Old 12-04-2008, 02:51 PM
On the road...
Correct, Mach3 and your PC constitute your controller. It is capabale of 3 axis interpolated moves, and I believe up to 6 axis (personally I haven't even delved much into the 4th).
You may be able to keep your drivers and servos depending on the type and how you want to 'interface' with Mach/PC. The most direct/straight forward interface route is parallel port to optional BOB (breakout board) to step/dir capable servo drivers/amplifiers (e.g. Gecko 320) with encoder feedback to the drive.
Your current servos and amps are likely not step/dir and encoder feedback, but more probable +10 analog with tachometer and encoder or resolvers for feedback to the amp/controller. If you wish to retain these, you will need to look into alternative interface hardware, e.g. Galil, CNCBrain, or EMC2(PC control SW) and Mesa 5i20/7i33, etc.
Your z is currently servo driven? Just not interpolated moves?
Mach to EMC conversion guide? randyf1965 LinuxCNC (formerly EMC2) 11 03-05-2008 11:06 AM
BP Series 1 Anilam > Mach conversion...? arpieb Bridgeport and Hardinge Mills 12 01-04-2008 06:17 PM
Boss 8 to Mach Conversion Help TurboStew Bridgeport and Hardinge Mills 4 10-26-2006 08:44 PM
Practical cnc to Mach conversion cut more Machines running Mach Software 5 05-25-2006 12:22 PM
Beginning Crusader to Mach 2 Conversion Please Help MMT Bridgeport and Hardinge Mills 8 10-30-2005 11:13 PM
