how does it work? how do you like the Taig CNC mill?
I have been using the taig mill with Mach 3 for about 2 years. Mach 3 works great and the Taig mill has been working well. All of my milling has been in aluminum using 1/8" to 3/16" carbide and High speed steel endmills. I have added extra bracing to the vert. column of the taig as there is only one bolt that keeps the column in tram. This extra bracing also helps eliminate vibrations.
Scott
