| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
After all is said and done with wiring up a relay through a pc and runing mach3...does anybody know how to make the relay turn on and off at fluctuating times during the run time of a project...basically I want to run a vacuum but not for the full duration of the job....rather every 5 mins... thanks cncguy toronto |
| If you do not want to be bothered to place M codes throughout, the practical way may be to place an external hardware timer relay that would replace the normal on/off relay and it would cycle on/off at preset times, It would be picked up by a M code at the start of the pgm and another at the end to disable it. I am not sure if Mach has a software timer function to implement this in software? You could also place an external bybass toggle switch to effect a continuous on time. Al.
| Too many "M00"s. stops and starts | mike hide | SheetCam | 3 | 09-15-2008 06:04 PM |
| I put Carriage stops / E-stops on the x&y Shoptask 1739 Gunmaster....I was bored lol | spunky1974 | Shopmaster/Shoptask | 0 | 06-30-2007 04:13 PM |
| Spindle starts in windows explorer | cut2spec | Benchtop Machines | 4 | 02-26-2007 06:49 PM |
| Hyudai starts in metric | Jedi | General Metal Working Machines | 0 | 10-17-2006 07:23 PM |
| Starts | AZCoyote | CNC Plasma and Waterjet Machines | 12 | 01-20-2005 05:33 PM |
