Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-06-2008, 04:10 PM
SPEEDRE is on a distinguished road
RE Router Starting
So , if I need a relay board, What is a relay board. Are any available pre made so I can wire the router to it and pick a pin to activate ?
Old 08-06-2008, 04:28 PM
ger21's Avatar
http://www.cnc4pc.com/Store/osc/prod...roducts_id=132
http://campbelldesigns.net/parallel-...elay-board.php
Old 08-08-2008, 07:51 AM
Thank You ger21. That's just the ticket. Kudos
starting a 6' x3' router table with mdf/angle sawmiller DIY-CNC Router Table Machines 24 01-12-2008 04:52 PM
starting cnc router/mill krymis DIY-CNC Router Table Machines 4 06-28-2006 12:12 PM
Starting CNC router, need some advice Oracle_9 DIY-CNC Router Table Machines 2 06-27-2006 10:00 PM
My router is finally starting to be built phantomcow2 CNC Wood Router Project Log 2 01-20-2006 05:21 AM
Finally starting on router project ehiebert DIY-CNC Router Table Machines 9 04-10-2004 07:07 PM
