Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 08-03-2008, 01:48 PM
AngelT is on a distinguished road
Mach4?
When I open an art file with Corel Draw 12 and save as a *.dxf and imported to Mach3 it says that it is a Mach4 file...How can I open it with Mach3? thanks for any imput...
Old 08-03-2008, 02:27 PM
jalessi's Avatar
jalessi is on a distinguished road
Are you using LazyCam to open the DXF?
Jeff...
Old 08-04-2008, 07:33 AM
Not using Lazy Cam as this feature it is only found on new Mach3 versions.
Old 08-04-2008, 12:56 PM
jalessi's Avatar
Smile
Angel,
Mach itself wont process a DXF, you need to process the DXF in LazyCam or some other Cam product that will output in Gcode.
Then input the Gcode into mach3 and output to your cnc machine.
Jeff...
Old 08-04-2008, 06:08 PM
ger21's Avatar
The older versions of mach3 can have a .dxf converter. You access it under File > .dxf import or something like that.
Are you saying when you try to import the .dxf file, it gives you an error? Can you post a screen shot of this error? And can you post the .dxf here?
Old 08-04-2008, 06:55 PM
jalessi's Avatar
Smile Sorry for giving bad information.
You might want to check in with the Mach support forum.
http://www.machsupport.com/forum/index.php
Jeff...
G100 firmware with Mach4 efrem Mach Software (ArtSoft software) 0 10-11-2006 08:51 PM
Mach4 & gecko g100 efrem Machines running Mach Software 4 07-14-2006 01:17 PM
Mach4 and G-Rex Death Adder Mach Software (ArtSoft software) 5 04-20-2006 01:23 AM
Not sure if this is a Mach4 question or G-Rex srbliss Mach Software (ArtSoft software) 8 03-14-2006 06:33 AM
