Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-01-2008, 11:10 AM
SPEEDRE is on a distinguished road
Cutting Air ?
Well, I pressed the button, and here's what happened. My machine ran smooth and where I wanted it, position wise, but. The Z axis went too far, right into the table, it's MDF, ramped up and proceeded to cut air, and only half of the part was cut, according to the little screen that shows where and what is cutting on the Mach 3 screen. Can anybody venture a guess as to what I've done wrong !!!!!! Why would it ramp up when I did not add a ramping function to my toolpath save?. Here's the toolpath code as an attachment.
Old 07-02-2008, 02:47 AM
neilw20's Avatar
neilw20 is on a distinguished road
Question When where and how
When where and how did you set Z0 before running program.
Set Z inhibit to level of table. At least you can't go too low. Maybe you can also make the soft limit for Z work.
At first glance your program looks OK.
Why are there 2 G20's on line N020? Metric a few times NO !??
In line N050 I see you have tool length offset used. Does table H1 have some whacky values. I believe this is where the problem is.
Try commenting line 20 and see what happens.
If you Z zero is set correctly you should not hit the table with this program, provided the tool length table has sane values.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 07-02-2008, 10:23 AM
ger21's Avatar
You probably need to remove line N50 as well.
Old 07-02-2008, 11:24 AM
HuFlungDung's Avatar
Moderator
What is that expression I heard? "Information wants to be free, and code wants to be wrong". And we might add, "tools want to enter tabletops"
Old 07-02-2008, 05:39 PM
neilw20's Avatar
Talking Too late at nite.
I really meant N50 not N20. With no spaces in the file I went cross-eyed.
Old 07-02-2008, 07:34 PM
I did not program any of what you've mentioned. I did the toolpaths in V Carve 4.6. I do not know why this got messed up!!!!
Old 07-02-2008, 07:49 PM
ger21's Avatar
I just looked, and it's in the Post processor your using, looks like "Mach_2_3_Arcs_inch". If taking that line out works, I can modify the post for you to remove it.
Old 07-02-2008, 08:05 PM
ger21's Avatar
And btw, Neil was incorrect about the G20. It's for inch, not metric. I posted a note on the Vectric forum about fixing the two G20's in their pp.
Old 07-02-2008, 10:09 PM
neilw20's Avatar
oops.
Oops. I am in metric land, and got my wires crossed.
Old 07-03-2008, 09:01 AM
OK that sounds plausible. I was wondering which PP to chose there are so many in the V Carve PP list. Nielw20 I wish I could read and edit G code even a little but up until now have'nt had an interest in learning it. I guess I must to at least get this thing going. Thanks guys.
oxy gasoline cutting torch - oPetrol cutting torch denniswang Product Announcements & Manufacturer News 6 02-20-2010 04:23 PM
I need help about cutting heads which apply to apparel pattern cutting machine sheepgrass Mechanical Calculations/Engineering Design 0 05-12-2006 01:09 PM
Cutting Oil mjarus Safety Zone 11 04-15-2006 01:01 PM
Help with cutting set up landart DIY-CNC Router Table Machines 1 03-23-2004 03:52 PM
