| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
Ive had a play with Mach2 and am controlling 4 stepper motors which will one day be made into a 4 axis mill. My question is, can I get mach 2 to move or control a printer or plotter? I have an old plotter which still works (moves and does pen changes) I connected it to the printer port but cant seem to get any movement using Mach2. The plotter does have servos but all the controlling boards are in the plotter so Im asuming it just needs step/dir through printer port to the right pins. Has anyone done this before or is there something Im just missing here? Thanks |
| Some person very knowledgeable in software needs to write a driver (or may have already) so that the output from the port is the same language as the plotter. For instance HP and ROLAND plotters can understand HPGL. Mach3 outputs signals suited to stepper motor hardware driver modules.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Stuart... Have you had any luck finding out anything on this, i have a plotter too, and all i can come up with is something called winline, but its outside my price range right now...
__________________ Grizzly X3, CNC Fusion Ballscrew kit, 3 500oz-in bipolar steppers, 3 203v Gecko's, Linear power supply from Hubbard CNC, Mach 3, BOBcad Pro Art V22, Rhino. |
| What winline does is optimize HPGL vectors to stop machine gun redundant penup-pendown sequences. It won't work with MachX. I believe it's intended purpose related to early poorly written drivers for plotters which would do a penup at the end of a vector, and pendown at the start off the next vector, even if doing a straight line made up of two joining vectors in the same direction. This sounded like a machine gun, destroyed pens and took forever, but sure kept the expensive pens from ever getting blocked. That's museum stuff now. google gcode to HPGL will give you plenty to figure out how to do what you want. I found the opposite straight away. Keep looking.. HPGL to GCODE conversion so that MachX can understand HPGL. http://www.metalgeek.com/archives/2004/06/03/000028.php |
| using the cnc as a plotter or printer | woodman08 | Gorilla CNC Machines | 2 | 01-20-2008 07:35 AM |
| Does anyone here want solvent printer,engraver,or cutting plotter? | lolyjet | Product Announcements & Manufacturer News | 0 | 12-20-2006 03:05 AM |
| make a Plotter of an old printer? | sbucher | Printing, Scanners, Vinyl cutting and Plotters | 1 | 05-13-2006 11:17 AM |
| I want to write printer driver for my plotter device. | bunalmis | OpenSource Software | 8 | 02-28-2006 12:31 PM |
| Help with controlling CNC! | Kammo1 | Stepper Motors and Drives | 2 | 06-11-2005 02:54 PM |
