Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 04-23-2008, 04:02 AM
beezerlm's Avatar
beezerlm is on a distinguished road
Question Missing steps?
Hello,
I just removed an anillam control from an lagun mill and installed the following:
1. Viper 200 from Larken for X,Y,Z
2. 3 USD 500 cpr encoders
3. Bob Campbell's BOB
4. Mach 3 software
If I set a zero, walk away an inch, and then walk back my machine is off 02" to .04". It does this on all axis and is cumulative. I have tried playing with the pulse settings and switching to a different BOB and no Luck!
Has anybody experienced this problem before?
Brandon
Old 04-27-2008, 05:42 PM
Monte is on a distinguished road
Double checked your steps per unit values for each axis?
Monte
Old 04-28-2008, 01:53 AM
beezerlm's Avatar
yep.
Old 04-29-2008, 12:17 AM
Originally Posted by beezerlm View Post
yep.
So when you walk away an inch, does the table move an inch (1.000") AND the DRO indicates the same inch (1.000")? Have you tried moving further in the same direction?
Monte
Old 05-12-2008, 09:59 PM
duyngdang is on a distinguished road
Unhappy
Somebody help:
The more pulse (2000 pulse) of encoder is the more accuracy will get?
Tags
error, location, missing, position, steps
Missing steps on just a certain part of the part ZipSnipe Stepper Motors and Drives 5 01-02-2008 01:40 PM
Servos jumpy n missing steps.... bigal Gecko Drives 8 09-29-2006 03:52 PM
Missing steps ? DavyD Machines running Mach Software 9 05-10-2006 02:06 AM
Full Steps -vs- Micro Steps DJB282000 General Electronics Discussion 10 12-28-2005 11:25 PM
Missing Steps with Laptop alanc2 TurboCNC 6 08-08-2004 02:39 PM
