| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
Hi I started mach3 and the machine. As soon as the machine power was on all axes took off on their own. As a troubleshooting test I started the machine. The servos were holding just fine. I then started the PC. As soon as I started to load Windows the motors started spinning slowly. When Windows had loaded completely the motors were spinning at maxium speed. I`m using mach3 version 2.6. I`m also using the sound logic encoder interface for servos on my machine. Also, no changes have been to the xml config files or any modifications to the wiring of the system. I am getting voltage readings to the sound logic encoder card from the encoders. I also jus replaced the sound logic encoder board but that didn`t seem to help. Recently I checked both parallel ports by using a old dot martix printer. It seemed to show the ports were working. Barry |
| Sounds like maybe the charge pump is not working correctly.
| G320 not singing? | Chris64 | Gecko Drives | 4 | 01-30-2008 08:01 PM |
| G320 heatsinks | beezerlm | Gecko Drives | 2 | 01-09-2008 11:49 PM |
| g320 question | h_2_o | Gecko Drives | 4 | 11-21-2006 11:15 AM |
| Controller With G320 | kkilst | Gecko Drives | 1 | 05-10-2006 08:07 AM |
| alternative to gecko G320 | opl505e | Servo Motors and Drives | 14 | 01-18-2006 02:04 PM |
