03-24-2008, 11:00 PM
Flashcut to Mach conversion: boards? | | (I posted this on the FlashCut board, but it occurs to me that this is probably a better forum. Apologies for the double post.)
I've got an older (circa 2000) FlashCut system hooked to a ShopMaster/ShopTask Eldorado 2000. I've now figured out many of the features, but I'm quite disappointed in the older versions of FlashCut - they seem extremely limiting.
I've downloaded the newest FlashCut version, but it won't work without an expensive update to my controller. It still doesn't seem quite as functional as I'd expect.
After some flddling around with different software, it seems that Mach has an edge with the number of people who are doing interesting hacks with it, and it seems more widely supported. I very much like the "wizards" which seem to be just what I need for quick projects without firing up the whole CAD program to do really simple stuff that crops up on a daily basis. The folks at Artsoft say that I can hook my parallel port directly up to the stepper controller with a bit of work.
What I'd like to do is find out if there is a board that anyone sells which has the correct pinout conversions between the two DB-25 connectors, and possibly has the Molex-style connectors for my limit switches so I can just plug-and-play. It would save me a day or two of cursing and logic probing and soldering, which is all fine and good but my time is somewhat limited for trial-and-error wiring, which from past experience takes 10x(time) what I expect it to.
JT |
