Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-24-2008, 02:16 PM
pminmo's Avatar
pminmo is on a distinguished road
Smile MACH3 Laptop Success Stories
Seems in reviewing people using laptops with MACH3 is a mixed bag. Some succeed, some don't. (I think I want to buy a laptop...but only if I think I can use it with MACH3) The fundamental question becomes, is it something happening with the laptop internals, software setup, or is it a hardware interface problem with the controller hooking to the laptop parallel port. So for those considering a laptop to run a machine from a parallel port with MACH3, if you are one of the success stories, can you post what make/model laptop?
Phil, Still too many interests, too many projects, and not enough time!!!!!!!!
Vist my websites - http://pminmo.com & http://millpcbs.com
Old 02-25-2008, 02:00 PM
turmite is on a distinguished road
Save your money if you intend to only use Mach to provide step/direction to your drives. The laps only put out 3.3v and 5v is absolute for that need. Now on the other hand, if you want to use Mach as the gui,smooth stepper as your step/direction, it might work. This is the direction I want to go if the new smooth stepper and Mach will work with a lap top.
Mike
ps smooth stepper is a pulse engine much like the G100 from Gecko, but the smooth stepper as been getting rave reviews from the beta testers.
No greater love can a man have than this, that he give his life for a friend.
Old 02-25-2008, 02:28 PM
bclark6716 is on a distinguished road
Phil,
I only use a laptop to run Mach3 and an Exitech 0609 CNC Router.
The laptop is a Compaq Presario running XP Pro. Absolutely no issues with 3.3 or 5.0 ttl logic levels. The parallel port is built-in so not much of a problem.
Brian
Old 02-25-2008, 03:29 PM
Originally Posted by bclark6716 View Post
Phil,
Brian
Well, that just goes to show you can't believe everything you read! I would be very interested in your model specs just as pminmo is.
Mike
Old 02-25-2008, 04:09 PM
I will get some info and post tomorrow morning.
Old 02-25-2008, 04:21 PM
alufly is on a distinguished road
I use a fijitsu lifeBook oldish laptop with a p3 running at 1Ghz works fine just had to disable all power options and all startup applications and anything else I could find running in the backround
Old 02-26-2008, 06:46 AM
Oldmanandhistoy is on a distinguished road
I posted a while back with a similar question so am also interested in any good/bad experiences with Laptops.
John
Old 02-29-2008, 11:41 AM
cut more is on a distinguished road
I run Mach controlling an engraver,cnc saw,cnc lathe, Not all at once though! Using an old dell 650mhz laptop. It out puts a 3.3-3.5v signal.
I just use a breakout board, like the cnc4pc c10 and it works fine for me.
There service has been great.
Cutmore
Old 02-29-2008, 03:44 PM
wwendorf is on a distinguished road
I use my HP 3010us laptop with built in parallel port just fine. I did have some problems with on of the drivers, and since I thought it was a 3.3v port problem, I actually bought a dedicated computer for the shop. Only to find out it was a bad board. Now I can use my laptop or my desktop with my Syil SX3 just fine.
Wade
Old 03-03-2008, 10:59 AM
RRFireblade is on a distinguished road
Mixed bag is quite accurate.
I have/did run it using my older IBM Laptop , it's an absolute tank of an older laptop and ran it fine. I have two others that I have tried to run it on , both quite new and quite powerful that won't do it due to enough or reliable enough voltage output.
Ultimately , as most suggest , I just ran and picked up a used Desktop from a local source , w/ LCD too , for something like $250-ish and have been perfect ever since. Plus it's strong enough now that I can easily work in my CAD/CAM will parts are running.
  #11   Ban this user!
Old 03-06-2008, 12:08 PM
pminmo's Avatar
Ok, I decided to take a leap of faith/experiment and bought an old Dell C610 which is a 1Ghz P3 with 386K of ram. Initial driver tests are all over the place which isn't a big surprise as there are a lot of potential settings that intuitively look like they could be an issue. I don't want to do too much tweeking yet as I'm waiting to see if I can get backup CD's from Dell, as I just have the machine with a valid COA for XP Pro. No real way to get a valid image of the HD easily that I can figure out. I did a Microsoft Image backup to a network drive, but it's based on a floppy boot and I'm not real comfortable that it would work. The HD on the laptop is one partition, no hidden partition........
  #12   Ban this user!
Old 03-06-2008, 02:52 PM
fatal-exception's Avatar
fatal-exception is on a distinguished road
Pminmo, wish I would have read this post a few days ago. The dell c610 won't do it for you. I've tried 2 of them to no avail. Sold one already, kept one for solidworks. Once you make them 'Standard PCs' they will at least run Mach3, but there's an internal problem somewhere that causes the pulse rate to suddenly drop out, then come back, causing havoc on your machine tool. (This was especially bad with servos, since they would sometimes enter fault mode.) I tried everything I know of but was unable to get rid of the pulserate problem.
Let me know if you see the same behavior.
That being said, I have one machine that is controlled using a Toshiba Tecra S1, and it works flawlessly. The only thing I had to do was disable qtask.exe. I can even have mail open and wireless always on, and it dosen't affect the machine tool.
Other experince:
Compaq Evo desktop @ 2gHz - no go. same problem as the dell laptops.
Crappy Dell desktop @ 1gHz (the miniture type) works perfect.
Paul
LinkBacks (?)
LinkBack to this Thread: http://www.cnczone.com/forums/machines_running_mach_software/53254-mach3_laptop_success_stories.html
Posted By For Type Date
PMinMO.com • View topic - Laptops and Mach3 This thread Refback 10-04-2010 05:07 AM
Anyone with Mesa 5I20 and 7I33 stories? karl1 LinuxCNC (formerly EMC2) 15 12-13-2008 11:28 PM
mach3 will not work properly on a laptop woodman08 Machines running Mach Software 9 04-07-2008 11:21 AM
Newbe Laptop for Mach3 dkb23 Machines running Mach Software 0 11-13-2007 10:59 PM
Success HX6090SE pedroman Laser Engraving & Cutting Machines 1 05-25-2007 08:02 PM
Mach2/Mach3 installation problem (laptop) xyz100 Mach Software (ArtSoft software) 3 07-25-2006 08:56 AM
