Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-24-2008, 08:18 AM
Cosha is on a distinguished road
Mach3 Wont Run - Setup Help
Hi All my First Post!
i have been working for 2 weeks trying to get mach3 to run my controller and motors
im using windows 2000
mach3 loads no problem
i have done this:
Entered Bios Port Setting "SPP 378"
Gone to ports and pins in mach3 changed port 1 into "0x378" Clecked port enable, kernel speed = 25000Hz Port2 disabled
Motor outputs x,y,z enabled (Green ticks)
The cnc controller is made by damen cnc and came with the pin set up
PIN:1 spindle
PIN:2 DIR X
PIN:3 STEP X
PIN:4 DIR Y
PIN:5 STEP Y
PIN:6 DIR Z
PIN:7 STEP Z
ETC.....
Then in motor out puts i haved used that to changed the step pin# and Dir pin# & DIR low/active enabled & STP low/active
Still Nothing, Mach3 shows that the motors should be running (Simulation) but the motors dont move, i have all the correct lights on my controller has full power, i have set up the E-Stop so mach3 resets and have used mach3 set up guide to the TEE!!
i know theres just one little setting that i have missed or a setting!
i know my controller works and motors as i have used in using kellycam on another pc
any help would be great!
osha
Old 02-24-2008, 10:03 AM
H.O H.O is offline
H.O is on a distinguished road
First you need to make sure that 378 is the correct adress. Second you say that the controller work on another computer, that's good. The problem could be that the parallelport on this computer only outputs 3.3V and the controller needs 5V (laptop by any chance?)
If you have a voltmeter please meassure between ground (pin18-25) and pin2 (X-DIR) of the parallelport. Then jog in one direction, you should see very close 0V when jogging in one direction and close to 5V when jogging in the other.
/H.O
Old 02-24-2008, 10:22 AM
ger21's Avatar
enter 0378 as the port address
Old 02-24-2008, 10:41 AM
MarkWink is on a distinguished road
Cosha,
Does the Damen CNC board use opto isolators to protect the PC?
If so you may want to run - sherline mode (it's a check box setting in the setup area)
Old 02-24-2008, 07:38 PM
jfc11 is on a distinguished road
Make sure the mach driver is installed...look in the system files....another gentleman had that same promblem and that was the cause...
jim
Old 02-26-2008, 09:48 AM
Smile
Hi all thanks for the replys!
sorry its taken a long time to respond (im a weapons tec for the mod and i been working stupidly hard recently)
ok i started from scratch again!
Bios SPP mode 378
Re installed Mach3
Re installed Drivers
Configured Out Everything!
Still NOTHING!
Then In Ports and pins Motor Options, i replaced the ports used to all Number 1's as i was using that port selection - Still Nothing
Rebooted and....
ITS WORKING PERFECTLY! PHEW!
i Knew It Would Of Been something small that i missed out!
i used a MACH3 set up help file and i cant remember it saying to set up the ports to all 1's!
Thanks everyone for your help!!
Cant wait untill the rails and lead screws get here in a few days!!!
Thanks Again!
I Hope somone reads this who has the same problems to check on it!
EDIT - just watched the mach3 help video - DOH it says it clearly....how did i miss that!!
Is this a good PC setup for Mach3 ? cnczoner General CNC (Mill and Lathe) Control Software (NC) 3 06-26-2007 08:25 AM
Syil X2 setup with Mach3 43hudson Syil Products 3 03-27-2007 07:52 AM
More Mach3 Setup Questions bill south Mach Mill 2 05-08-2006 10:10 AM
Mach3 setup mlaws1172 Mach Plasma / Laser 6 11-30-2005 10:14 AM
