Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-22-2008, 11:44 PM
woodman08's Avatar
woodman08 is on a distinguished road
running mach3
I tried running mach 3 with a notebook that has a lpt port configured the same as a desktop computer i was using.
The cnc went crazy ,sounded like the bearing and gears were not meshing properly ,manufacturer says laptops and mach 3 don't get along very good ,the lpt port on the laptop can be used but has to be set up ,anyone have experience with this
woodman
Old 02-25-2008, 09:30 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
If I use my laptop to a driver board what does not require a BOB it does not work, if i use it with an iso. bob with its own 5v PSU it works fine. What Drivers are you useing and if so what BOB?
Joe
Old 02-26-2008, 08:14 AM
woodman08's Avatar
mach 3 and notebook
not sure what you mean about drivers there are no drivers for an lpt port ,i just replaced the dsesktop with a notebook same mach3 settings and it works fine testing with the arrow keys but when i run gcode the machine goes crazy and there are no settings to change.
Its almost as if the notebook does not send a continuous signal,tried the bi direction and 2 other settings
Other people are reporting the same problem and my notebook is older as new ones don't have a lpt port
Old 02-26-2008, 08:52 AM
joecnc2006's Avatar
www.joescnc.com
Motor Drivers, not driver for lpt port that is built into windows.
the problem is the 3.5v from the printer port on the laptop, the bob card will up this to the required 5v and improve signal strength. this was the case on mine and I run my CNC 4x4 Hybrid with a Toshiba laptop now.
Joe
Old 02-26-2008, 10:21 AM
ger21's Avatar
It could be lots of things. Mach3 won't run on a lot of notebooks, and for some, you may need to disable a lot of things to get it to work properly. It varies from laptop to laptop. It could also just be as Joe said, 3.3V ports.
Running flood coolant from Mach3 BrassBuilder Benchtop Machines 15 02-12-2008 11:50 PM
Running Mach3 for laser cutting questions CNCadmin Mach Plasma / Laser 9 09-14-2007 10:34 PM
Laptops Running Mach3? Fred Kelly Shopmaster/Shoptask 5 09-10-2007 08:07 AM
Anyone running Mach3 with a DynaCNC table top? CrashMasterKev Machines running Mach Software 1 11-21-2006 08:36 PM
Mach3 running the new G203 Vampire drivers Dan Mauch Gecko Drives 0 11-15-2006 01:00 PM
