Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-06-2008, 11:08 PM
draughted's Avatar
draughted is on a distinguished road
port options?
mach 3 seems like a great piece of software but i'm just concerned as to if it will support my serial controlled controller, which i would also like to convert to usb to future-proof it. I'm reading the user'sguide and in noway does it mention anything other than parallel.
any one know better?, maybe some first-hand exerience.
thanks
Old 02-07-2008, 10:27 AM
ger21's Avatar
Mach can only export step /direction signals from the parallel port.
There is an exception. Mach3 plugin architecture allows plugins to be written to support external pulsing engines. Currently supported devices are the Gecko G100 (ethernet), ncPod (USB), SmoothStepper(USB) and certain PCI Galil cards.
Old 02-08-2008, 05:00 AM
draughted's Avatar
ok, that's unfortunate.
maybe ill look at different software, any suggestions?!?
Old 02-08-2008, 08:12 AM
ger21's Avatar
I'm not aware of any that use the serial port.
X2 Options wocowski Benchtop Machines 12 11-25-2007 07:31 PM
To many options dalescnc PicStep Controllers 1 08-04-2007 09:12 AM
Parallel Port Options JasonCroyle General Electronics Discussion 4 01-12-2005 07:23 AM
Help with CNC options please djshop General CNC (Mill and Lathe) Control Software (NC) 0 01-05-2005 10:45 AM
