Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 02-05-2008, 12:04 PM
tz1238 is on a distinguished road
Limit Switch Problem
I have all my limits set to pin 13 on my BOB. 5 volt input. When I set to active high, my limits do not work. When I set my limits to active low, like my home switches, I cannot reset the E stop.
Old 02-05-2008, 04:23 PM
I just noticed that my Manual Limit override is flashing in the Settings screen. I 'm wondering if this is related to my other problem. How do I correct this?
Old 02-05-2008, 08:56 PM
BobF is on a distinguished road
How are your limits wired?
Old 02-06-2008, 06:01 AM
Yes, all my limits switches are working. I have them in series.When I go to diagnostics screen, and trip one of the switches, all three lights go on as expected. I have them set up for 5 volts. Everything seems hooked up correctly, but when I run an axis to the switch, it will not stop. I get no EStop. I have tried active high, active low, to no avail. Like I said, The manual limit override is constantly flashing. Is there a way to reset or turn this off?
Old 02-07-2008, 04:00 PM
I had my limit set incorrectly in the input section of setup. I just didn't scroll down far enough. Thanks for all the help.
Limit switch problem jimini Mach Software (ArtSoft software) 5 09-17-2007 08:49 PM
Mach3 limit switch problem on Ref Home originator Mach Software (ArtSoft software) 1 03-13-2006 08:02 AM
Problem With IH Limit Switch. Willyb Industrial Hobbies (Support forum) 5 11-06-2005 05:17 PM
Limit Switch / Home Switch in Software Sanghera General Electronics Discussion 6 11-01-2004 05:58 PM
