Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 01-29-2008, 08:45 AM
Ed Williams is on a distinguished road
Please help with limit switches
If I have limits on home what pins do I use on break out board. Would it be 11=x home,12=y home and 13=z home. And with the switches set to NC would I connect the other side of switch to machine ground or run them back to power ground on break out board. What pin do I use for going to far on the limit switches.
Thanks Ed
Old 01-29-2008, 05:07 PM
Gold Member
mlaws1172 is on a distinguished road
Ed
it will depend somewhat on the breakout board. usually it is pin 11 or 12 then you return the wire to breakout board ground
mike
Old 01-29-2008, 06:38 PM
ktb100's Avatar
ktb100 is on a distinguished road
If using a board like this http://www.cnc4pc.com/Store/osc/prod...products_id=45
Pin 10 = X, 11= Y, 12 = Z, Between the pins are +5vdc. So run the 5vdc to the switch and return to the appropriate pin number. Set the travel for "too far" in the software / soft limits. I only use one switch per axis.
Limit switches and homing switches AeroKam Open Source CNC Machine Designs 16 01-05-2008 07:56 AM
Limit switches Chunky DIY-CNC Router Table Machines 4 06-06-2005 09:28 AM
The relationship of limit switches to home switches. MikeAber General Electronics Discussion 4 11-04-2004 01:28 PM
Limit switches and home switches viktorcnc TurboCNC 2 08-03-2004 06:11 AM
Home switches and limit switches. ynneb General Electronics Discussion 5 04-08-2004 05:32 PM
