Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-19-2007, 08:55 PM
ProDrawerCom
IQChallenged is on a distinguished road
Disturbing Clank on RESET
Hard to know exactly where to post this. I've been using my machine for close to a year now and I'm amazed at how my home-built CNC can execute tiny changes in code and do such consistently good work despite my rookie status. One thing that's bothered me since day one is a metallic sounding clank each time I reset Mach. Each time I start the program it requires a reset. I assume that's the way it's supposed to be. But each time I click on it at start up or after I bump a limit, I get this disturbing clank. You can even feel it in the frame. I can't help but think somethings being damaged or at least thrown off position. I do have rack and pinion in all three axes and I suppose it could be related to that. But I really have no idea. I have 640oz stepper motors. Anyone got any ideas?
Old 12-20-2007, 01:12 AM
neilw20's Avatar
neilw20 is on a distinguished road
Talking Clunk!
Emergency stop removes power from your steppers, I believe, so when power is restored after a reset, all the steppers do a thump as they line up with their nearest step. I got used to it, and try to use soft limits, so I never need emergency stop.
Why do you need to reset. Put a M30 at the end of your program, or use the rewind button. You can hit program stop (Escape) at any time, then manually retract Z, hit rewind. And restart your program - no clunks except at initial power-up. Even changing programs does not require reset. Just Hit STOP.
It sounds worse than it is I think. Just 3 or more strong steppers jumping half a step or so to line up with the nearest pole.
Make sure the couplings to the stepper motors are well secured against slippage.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Old 12-20-2007, 06:15 AM
ProDrawerCom
Originally Posted by neilw20 View Post
I got used to it, and try to use soft limits, so I never need emergency stop. Why do you need to reset. Put a M30 at the end of your program
1. Thanks for the response
2. How do soft limits work?
3. Why do I need to reset? From inadvertently slamming into a switch while manually moving the spindle for cleaning the table, clamping the piece, etc. Another way I "bump out" is when I try running the Write Wizard. I haven't quite figured out how it zeros and consequently it runs into a switch before I can stop it.
Old 12-20-2007, 06:51 AM
neilw20's Avatar
RTFM
Read The Friendly Manual
1.) You are welcome.
Have you satisfied all of the requirements in section 4 ?
Have you setup EVERYTHING in Config>?
1a.) What sort of machine are you using?
2).) RTFM. Section 5.6
Do you reference the machine? Section 6.2.2.2
3.) Section 6.2.1.1
Its all in the manual. Read it, discover, fix, then ask of the more difficult mysteries.
Old 12-20-2007, 07:49 AM
ProDrawerCom
"Read The Friendly Manual"
Will do.
machine reset parameter priyo Mazak, Mitsubishi, Mazatrol 1 11-28-2007 12:45 AM
Reset Parts Counter martsto Milltronics 2 09-18-2007 10:59 AM
reset zero jrick Commercial CNC Wood Routers 7 01-13-2007 04:54 PM
VMC-966 (reset) )= novydcute General Metal Working Machines 0 10-18-2006 02:09 AM
MM2001 reset (or not...) Jalex CNC Wire Foam Cutter Machines 0 04-29-2006 11:20 AM
