Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 12-08-2007, 01:34 PM
elgonzo is on a distinguished road
motor setup help ????
Hello all,
I am in the process of setting up mach3. I have set up all my input and output data and am able to spin all the x,y and z motors using the MDI screen.
My issue is with the "motor tuning" screen. I'm not sure what value to input for the "steps per" field. The info for my machine is as follows:
-using a 4.29:1 gear reduction
-running the gecko's at full step
- rack and pinion grear is 0.750" DP on a 20TPI rack
I have calculated 1step = .0027 " per step final drive ( .0750*3.14/4.29/200 )
What value should be entered in the "steps per" field as i am not sure what this unit is asking for !!
thanks for any help in advance !!!!
Old 12-08-2007, 03:50 PM
ger21's Avatar
Use the axis calibration on the settings screen, just above the reset button.
Output of Encoder of Servo moto?? Thinh VN Servo Motors and Drives 2 07-08-2007 12:09 PM
What's your setup like... Scratch CNC Plasma and Waterjet Machines 1 01-12-2007 01:31 PM
What is your setup? dolanosa CNC Wire Foam Cutter Machines 5 10-09-2005 02:00 AM
Moto GP back in the US! Anyone going? Rekd CNCzone Club House 0 03-03-2005 04:52 PM
Anyone know anything about this setup? efreak DIY-CNC Router Table Machines 1 08-29-2004 12:27 AM
