| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
Trying to tune motors in Mach. I have CandCNC's PlazPak1A with G203V Gecko's 200 steps/rev. I have 4:1 reductions. pinions move axis 2.355" / rev. I didn't know how the CandCNC kit was set up (microstepping) so I asked : --- In CandCNCSupport@***********.com, "millman_52" <millman_52@...> wrote: > > For calculating steps for entry in "motor tuning" in Mach. > > Is my Plaz Pak set up standard with no microstepping as supplied from > candcnc? > We use Gecko drives exclusively. All Gecko steppers are X10 microstepping for any calculation. so is the following correct? 200 X 4 = 800 800 X 10 = 8000 1 / 2.355 = 0.4246......... 8000 X .4246..... = 3397.03 so I would plug in 3397 in : Confi / Motor Tuning / Steps Per
__________________ If it works.....Don't fix it! |
| Looks right.
| I also dont have a clue how to configure my motor ect .... I got a 1600 driver --- 200 step motors 15 tooth timing pulley attached to the motor connected to a 45 tooth timing pulley (3 :1 reduction i guess). the 45 tooth is attached to a shaft which has a 32 tooth timing pulley on a belt with a 5mm pitch ..... i read the mach2 setup and it still aint making sence ..please help! |
unfortunately your 32 tooth pulley driving your belt is just about going to cancel out your 3:1 reduction. If I am reading your post correctly 1 turn of your reduction shaft is going to move your axis 160MM. Is this corrcet? Once I am clear I can help you calculate your steps per. for Mach.
Set a starting number in the units per value like 2000 Clamp a digital caliper on to the axis and set to zero. Move the axis one inch and write down the results of the digital caliper movement. Let say it moved .950 . Take the programmed value and divide it by the actual movment value. Multiply that value times the units per value to get your new units per value. (1.000/.950) * 2000 = 2105.26 (Programmed/Actual) * Old Units Per = New Unit Per No silly gear head math required. But, it's good to know the gear head math if you really want to learn Last edited by WayneHill; 11-28-2007 at 08:16 AM. |
| I agree Wayne. I took the time to make very precise calculations on the reductions, gear teeth etc. The reality was once I had my table moving, I still had to do exactly as you state. Take a precise measurment at the table & found that I was off still by several thousandths. Adjusted steps per till I had it dead on. Then I double checked over a long run on my X axis. Wrote in a 1 line Gcode to move the X 10' It moved 10' exactly. At least as good as one could measure with a tape rule.
1 revolution on the stepper motor should translate to 53.33mm (Permanent 1/8 microstepping on all 4 axis', that's 1600 steps per revolution-) 53.33/1600 = 0.03331 ---- which is close enought for a wood working cnc. Ger1 sent me a private message last night explaining Mach 3 ---''set steps per unit '' on the settings tab .......learn something new every day --havent tried it yet but would like to back it up with some calculations! |
| DynaCNC 24"X36" and Mach3 | wellbuiltcabs | DynaCNC | 4 | 12-31-2007 02:52 PM |
| What causes "missed steps"? | watsonstudios | Stepper Motors and Drives | 4 | 04-21-2007 07:43 AM |
| "BRAKE BOARD" NEW Design for MACH3 | Chivo | General Electronics Discussion | 1 | 04-08-2007 12:01 PM |
| Vertical system "jerks" and "bangs"?? | REVCAM_Bob | Servo Motors and Drives | 5 | 06-12-2006 09:09 AM |
| Calculating "steps per unit" for rotary axis? | Beezer | Mach Software (ArtSoft software) | 2 | 11-28-2004 03:31 PM |
