Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 11-03-2007, 11:47 PM
DDzHere is on a distinguished road
Mach 3 requirements
Okay i have searched there site a couple of times and dont seem to beable to find the pc system requirements for mach 3. Am i blind? Does anyone know what the min system would be?
THanks!
Old 11-04-2007, 04:51 AM
Khalid's Avatar
Khalid is on a distinguished road
Download the Mach3 documentation...
Old 11-04-2007, 06:56 AM
ger21's Avatar
1 Ghz if you want to run in 25Khz mode, 2Gz for 45Khz, and even faster if you want 100Khz. I'd also get a Gig of RAM or more, but it will run on less.
Old 11-04-2007, 06:57 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
The manual says 1ghz pc or better on Win. XP or 2000, desktop
This is the Mach3 manual I have, they might have a later release.
Right click the link and "SAVE TARGET AS..." it's a 5.62mb pdf file.
ftp://anonymous:guest@machsupport.co...M3M1_84-A2.pdf
Old 11-04-2007, 07:00 AM
Switcher's Avatar
Moderator
This link might also help you, to much to list.
ftp://machsupport.com/
Old 11-04-2007, 10:08 PM
Everything new i find has vista in it.
Old 11-05-2007, 08:10 AM
ger21's Avatar
Mach3 will run on Vista. There are instructions for Vista at the forum at www.machsupport.com
Old 12-15-2007, 06:42 AM
Skuzzy is on a distinguished road
Yes, but if you are stuck with Vista, you will need more CPU and RAM to have the same levels of performance as XP/2K.
You can still buy Windows XP Pro and most OEM's still offer XP Pro as an option. You just have to ask for it. I would stay away from Vista until Microsoft gets SP1 out for it. It has a lot of problems with drivers and general configuration issues.
Old 07-24-2008, 07:47 PM
corrie is on a distinguished road
Hello all. I,m thinking of switching over to mach from cncpro.
my first? is what is the difference between using xp pro or xp home edition? Also i can pick up a dell optiplex gx 150 for 50 bucks ,would this be suitable for mach3,thanks.
Old 11-16-2008, 10:56 PM
harryn is on a distinguished road
Single vs Dual Core for Mach, etc
Hi, I am slowly working my way toward a home built cnc router. The plan is to use Mach 3 running steppers, etc. The OS decision of Vista or XP is still open (I am comfortable with either and use both every day)
Drawing software like Lazy Cam, GCam, and possibly meshcam will also be on this computer.
I am looking at picking up a used desktop for the controller, and wondered if either of these have an advantage
a) AMD Athlon 64 single core 2.7 ghz with strong video card
b) AMD Athlon 64x2 dual core 2.2 ghz with modest video card.
The bottom line I guess - does Mach or LazyCam benefit from dual core on XP or Vista ?
HarryN
  #11   Ban this user!
Old 11-16-2008, 11:51 PM
JD68 is on a distinguished road
Don't forget to factor into this idea a motherboard with a parallel port.
  #12   Ban this user!
Old 11-17-2008, 03:26 PM
steve323 is on a distinguished road
Parallel ports are quickly disappearing from desktop computers. I ended up buying a motherboard that uses a 2-3 year old chipset just so I could get a parallel port. It is not surprising, since most new printers use USB. There was only 1 pre-built desktop system on the floor that had a parallel port.
Steve
Oscilloscope requirements? murphy625 General Electronics Discussion 15 01-16-2011 04:18 PM
trying to get definitive on PS requirements stirling Gecko Drives 3 08-22-2007 09:58 AM
G-rex with mach 4, Computer requirements? crazyman Mach Software (ArtSoft software) 4 11-17-2005 07:06 AM
PC Requirements Cyclone Computers and Networking 1 04-19-2005 08:57 AM
Power Requirements CapnC General Electronics Discussion 4 12-29-2004 10:39 AM
