Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 09-20-2007, 03:37 PM
Jonne is on a distinguished road
USB and Mach 3
Have anyone tried USB adapted paraller port on Mach?
Have those adapters some fysical I/O address?
How it works at all?
Old 09-20-2007, 06:12 PM
ger21's Avatar
A USB to parallel adapter won't work, but you can get an external motion controller that Mach3 can control via USB.
http://ncpod.oemtech.com/
Old 07-11-2008, 11:10 PM
Perfo is on a distinguished road
The USB to parallel may not work due to not many of them not being bi directional. Has anyone tried a PCMCIA card in a laptop with Mach 3. I can’t see why that wouldn't work or even try and get a second hand docking station for the laptop as most of these have the parallel and serial ports still on.
Old 07-11-2008, 11:16 PM
ger21's Avatar
That's not the reason that they don't work, but all that matters is that they don't work.
PCMCIA cards have worked for some, but others have not been able to get them to work.
If you must use a laptop without a parallel port, the SmoothStepper is probably your best bet.
How does Mach help rodneydeeeee Machines running Mach Software 11 06-22-2007 11:38 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Mach 3 no spindle - but OK in Mach 2 zcases Mach Software (ArtSoft software) 9 07-31-2006 07:38 AM
Moving to mach 3 need exact mach 2 screen carlnpa Mach Software (ArtSoft software) 2 12-11-2005 03:00 PM
will mach 2 or mach 3 work for 4 axis cnc? Runner4404spd Mach Mill 3 10-05-2005 11:44 AM
