Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > Mach Software (ArtSoft software) > Machines running Mach Software
Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here.
Old 07-29-2007, 03:47 PM
Green0 is on a distinguished road
Mach won't run my complete program.
It's stalling with no error as if the program just ended.
Today I got to the shop, and I have a working perfected code written with about 570 lines,
It's all hand written, because I don't know how to use automatic roughing and finishing, or drilling cycles with Mach3 and it won't take the cycles I am familiar with.
The control is stalling out at ~159. The notepad file doesn't display beyond that, nor will it run past that point.
I ran a Mach turn update, and that changed nothing.
So now a day is wasted.
Old 07-29-2007, 04:09 PM
The problem is there no matter what I do. At 159 it begins to repeat the last two lines over and over. it won't do anything longer than around 150 lines.
I can roll to the end of the program but it just takes those 135ish through 150 lines with it to the end of the program.
THIS IS THE PROGRAM:
T0303(face AND OD TURN)
G0 Z.1
G0 X1.0
G1 Z0.050F.004
G1 X0.0F.003
G0 X1.0
G1 Z0.025
G1 X0.0F.004
G0 X1.0
G1 Z0.0
G1 X0.0F.003
G0 X0.910
G1 Z-.700F0.005
G0 Z-0.460
G1 X0.8019 Z-0.525F0.006
G0 X0.910
G0 Z-0.410
G1 X0.7352 Z-0.525F0.006
G0 X0.910
G0 Z-0.360
G1 X0.6686 Z-0.525F0.006
G0 X0.910
G0 Z-0.305
G1 X0.6223 Z-0.525F0.006
G0 X0.910
G0 Z-0.250
G1 X0.575 Z-0.525F0.006
G0 X0.910
G0 Z-0.200
G1 X0.550 Z-0.525F0.006
G0 X0.910
G0 X0.910
G0 Z-0.150
G1 X0.500 Z-0.525F0.006
G0 X0.910
G0 Z-.110
G1 X0.450 Z-0.525F0.006
G0 X0.910
G0 X0.900
F0.006
G0 Z-0.09
G1 X0.400 Z-0.525F0.006
G0 X0.910
G0 Z0.0
G1 X.890F0.003
G1 Z-0.075F.003
G1 X0.380 Z-0.525F.003
G1 X0.890
G1 Z-0.700
G1 X1.0
G0 Z4.0
M1
T1515 (SPOT DRILL)
G0X0.0
Z.1
G1Z-.030F.003
G0Z4.5
M1
T1414 (17/64 BORE DRILL)
G0X0.0
G0Z.1
G1Z-0.2F.003
G0Z0.0
G0Z-0.18
G1Z-.4F.003
G0Z0.0
G0Z-0.38
G1Z-0.6
G0Z0.0
G0Z-0.58
G1Z-.8F.003
G0Z0.0
G0Z-0.78
G1Z-1.0F.003
G0Z0.0
G0Z-.98
G1Z-1.2F.003
G0Z0.0
G0Z-1.18
G1Z-1.4F.003
G0Z0.0
G0Z-1.38
G1Z-1.6
G0Z0.0
G0Z-1.58
G1Z-1.8F.003
G0Z0.0
G0Z-1.78
G1Z-2.0F.003
G0Z0.0
G0Z-1.98
G1Z-2.2F.003
G0Z0.0
G0Z-2.18
G1Z-2.4F.003
G0Z0.0
G0Z-2.38
G1Z-2.6
G0Z0.0
G0Z-2.58
G1Z-2.8F.003
G0Z0.0
G0Z-2.78
G1Z-3.0F.003
G0Z0.6
T1717 (5/16" DRILL)
G0X0.0
G0Z.1
G1Z0.0
G1Z-0.2F.003
G0Z0.0
G0Z-0.18
G1Z-0.4F.003
G0Z0.0
G0Z-0.38
G1Z-.535F.003
G0 Z0.25
M1
T1313 (ID BORING BAR)
G0 X0.300 Z0.041
G0 Z0.011
G1 Z-0.03F0.005
G1 X0.790F0.005
G1 Z0.041
G0 X0.300
G0 Z-0.016
G1 Z-0.057F0.003
G1 X0.790
G1 Z0.041
G0 X0.289 Z-0.057
G0 X0.345
G1 X0.289 Z-0.130F.005
G0 Z-0.057
G0 X0.3999
G1 X0.289 Z-0.208F.005
G0 Z-0.057
G0 X0.446
G1 X0.289 Z-0.288F.005
G0 Z-0.057
G0 X0.4922
G1 X0.289 Z-0.368F.005
G0 Z-0.057
G0 X0.5384
G1 X0.289 Z-0.448F.005
G0 Z-0.057
G0 X0.5846
G1 X0.289 Z-0.5074F.005
G0 Z-0.057
G0 X0.6308
G0 Z-0.057
G0 X0.677
G0 Z-0.057
G0 X0.7232
G0 Z-0.057
G0 X0.7694
G0 Z-0.057
G0 X0.800
G0 Z0.0
G0 X.807
G1 Z-0.057F.003
G1 X0.289 Z-0.5247F0.003
G1 X0.289
G0 Z0.25
M1
T0606(CUTOFF)
G0 X0.950
G0 Z-0.675
G1 X0.0F.005
G0 X.950
G0 Z1.0
G92Z0.0
M1
T0303 (outside turning-- Needs G43ish command)
G0 X.910
G1 Z-.700F0.006
G0 Z-0.460
G0 X0.910
G0 Z-0.410
G0 X0.910
G0 Z-0.360
G0 X0.910
G0 Z-0.305
G0 X0.910
G0 Z-0.250
G0 X0.910
G0 Z-0.200
G0 X0.910
G0 X0.910
G0 Z-0.150
G0 X0.910
G0 Z-.110
G0 X0.910
G0 X0.900
F0.006
G0 Z-0.09
G0 X0.910
G0 Z0.0
G1 X.890F0.003
G1 Z-0.075F.003
G1 X0.890
G1 Z-0.700
G1 X1.0
G0 Z7.1
M1
T1717 (5/16" DRILL)
G0X0.0
G0Z.1
G1Z0.0
G1Z-0.2F.003
G0Z0.0
G0Z-0.18
G1Z-0.4F.003
G0Z0.0
G0Z-0.38
G1Z-.535F.003
G0 Z0.25
G0 X0.300 Z0.041
G0 Z0.011
G1 Z-0.03F0.005
G1 X0.79F0.005
G1 Z0.041
G0 X0.300
G0 Z-0.016
G1 Z-0.057F0.005
G1 X0.790
G1 Z0.041 (end ID facing cycle)
G0 X0.289 Z-0.057 (BEGIN ID TAPER TURN CYCLE)
G0 X0.345
G0 Z-0.057
G0 X0.3999
G0 Z-0.057
G0 X0.446
G0 Z-0.057
G0 X0.4922
G0 Z-0.057
G0 X0.5384
G0 Z-0.057
G0 X0.5846
G0 Z-0.057
G0 X0.6308
G0 Z-0.057
G0 X0.677
G0 Z-0.057
G0 X0.7232
G0 Z-0.057
G0 X0.7694
G0 Z-0.057
G0 X0.800
G0 Z0.0
G0 X.807
G1 Z-0.057F.003
G1 X0.289
G0 Z0.25
M1
T0606(CUTOFF)
G0 X0.950
G0 Z-0.675
G1 X0.0F.005
G0 X.950
G0 Z1.0
G92Z0.0
M1
G0 X.910
G1 Z-.700F0.006
G0 Z-0.460
G0 X0.910
G0 Z-0.410
G0 X0.910
G0 Z-0.360
G0 X0.910
G0 Z-0.305
G0 X0.910
G0 Z-0.250
G0 X0.910
G0 Z-0.200
G0 X0.910
G0 X0.910
G0 Z-0.150
G0 X0.910
G0 Z-.110
G0 X0.910
G0 X0.900
F0.006
G0 Z-0.09
G0 X0.910
G0 Z0.0
G1 X.890F0.003
G1 Z-0.075F.003
G1 X0.890
G1 Z-0.700
G1 X1.0
G0 Z7.1
M1
T1717 (5/16" DRILL)
G0X0.0
G0Z.1
G1Z0.0
G1Z-0.2F.003
G0Z0.0
G0Z-0.18
G1Z-0.4F.003
G0Z0.0
G0Z-0.38
G1Z-.535F.003
G0 Z0.25
G0 X0.300 Z0.041
G0 Z0.011
G1 Z-0.03F0.005
G1 X0.790F0.005
G1 Z0.041
G0 X0.300
G0 Z-0.016
G1 Z-0.057F0.003
G1 X0.790
G0 X0.345
G0 Z-0.057
G0 X0.3999
G0 Z-0.057
G0 X0.446
G0 Z-0.057
G0 X0.4922
G0 Z-0.057
G0 X0.5384
G0 Z-0.057
G0 X0.5846
G0 Z-0.057
G0 X0.6308
G0 Z-0.057
G0 X0.677
G0 Z-0.057
G0 X0.7232
G0 Z-0.057
G0 X0.7694
G0 Z-0.057
G0 X0.800
G0 Z0.0
G0 X.807
G1 Z-0.057F.003
G1 X0.289
G0 Z0.25
M1
T0606(CUTOFF)
G0 X0.950
G0 Z-0.675
G1 X0.0F.005
G0 X.950
G0 Z1.0
G92Z0.0
M1
G0 X.910
G1 Z-.700F0.006
G0 Z-0.460
G0 X0.910
G0 Z-0.410
G0 X0.910
G0 Z-0.360
G0 X0.910
G0 Z-0.305
G0 X0.910
G0 Z-0.250
G0 X0.910
G0 Z-0.200
G0 X0.910
G0 X0.910
G0 Z-0.150
G0 X0.910
G0 Z-.110
G0 X0.910
G0 X0.900
F0.006
G0 Z-0.09
G0 X0.910
G0 Z0.0
G1 X.890F0.003
G1 Z-0.075F.003
G1 X0.890
G1 Z-0.700
G1 X1.0
G0 Z7.1
M1
T1717 (5/16" DRILL)
G0X0.0
G0Z.1
G1Z0.0
G1Z-0.2F.003
G0Z0.0
G0Z-0.18
G1Z-0.4F.003
G0Z0.0
G0Z-0.38
G1Z-.535F.003
G0 Z0.25
G0 X0.300 Z0.041
G0 Z0.011
G1 Z-0.03F0.005
G1 X0.790F0.005
G1 Z0.041
G0 X0.300
G0 Z-0.016
G1 Z-0.057F0.003
G1 X0.790
G0 X0.345
G0 Z-0.057
G0 X0.3999
G0 Z-0.057
G0 X0.446
G0 Z-0.057
G0 X0.4922
G0 Z-0.057
G0 X0.5384
G0 Z-0.057
G0 X0.5846
G0 Z-0.057
G0 X0.6308
G0 Z-0.057
G0 X0.677
G0 Z-0.057
G0 X0.7232
G0 Z-0.057
G0 X0.7694
G1 X0.289
G0 Z-0.057
G0 X0.800
G0 Z0.0
G0 X.807
G1 Z-0.057F.003
G1 X0.289
G0 Z0.25
M1
T0606(CUTOFF)
G0 X0.950
G0 Z-0.675
G1 X0.0F.005
G0 X.950
G0 Z2.7
G92Z0.0
M1
Old 07-29-2007, 04:24 PM
I'm not using cutter comp, because it seemed to want to arc onto and off of the part, crashing tools through the part.
It just wasn't working as it should.
In the same way, safety lines cause my machine to do funky things and crash, so I pulled safety lines also. I tested the G92's and they work so that shouldn't be the issue.
Old 07-29-2007, 10:40 PM
MrWild is on a distinguished road
I would be a little easier to follow your code if it had line numbers and where it goes wonky. I sure don't feel like counting 152 lines into your code.
Old 07-30-2007, 08:16 AM
mactec54 is on a distinguished road
Hi Green0
I think you have a problem with your feed rates & no callout as to what you want the control to do F0.003 is this the same as F3. being 3in per min I don't see any G90 G93 or G17 Etc the control needs to no what it has to do I'm surprised it run the first 157 lines.
Mach (Artsoft) has good information on there site as to all the Gcode you would need to use to get you going.
If notepad won't take your long program MS word will
Mactec54
Old 07-30-2007, 08:59 AM
Switcher's Avatar
Moderator
Switcher is on a distinguished road
When the program stops, Press "Cycle Start" again.
See If it picks up at the next line?
Old 07-30-2007, 10:07 AM
The G95 is a command I put in in advance before loading the program.
This thing loads and proofs on my laptop, but not on my machine control computor running a more recent version of Mach.
I don't want to uninstall it because I'll lose the machine settup.
I could probably get it to run in less than 159 lines with the appropriate cycles instead of what I'm using, if I just had an example of a canned cycle for automatic roughing/finishing, and for peck drilling.
If anyone can help with those that would be great. (I have the mach manual and it doesn't make the cycle format clear enough- no examples are provided).
I should have tried cycle start again- that sounds like a not half-bad idea-
Old 07-30-2007, 10:11 AM
ger21's Avatar
You can save your mach setup by saving the .xml file in the installed folder. Not sure about the lathe setup, but should be mach3turn.xml.
Old 07-30-2007, 10:38 AM
Switcher's Avatar
Moderator
How about all those M1 ?
Optional Program Stop Control
The optional program stop control works as follows. If this control is ON and an input line contains an M1 code. program execution is stopped at the end on the commands on that line until the Cycle Start button is pushed.
Old 07-30-2007, 02:41 PM
It was stopping at G0 X0.677 in the ID turning code.
The M1's are there for tool changes and they do stop the program, but don't stall it out.
Mazatrol Program into a G Code Program fuzzman Mazak, Mitsubishi, Mazatrol 14 02-08-2010 03:55 PM
How to remember the position after close MACH program?? jimmychand Mach Software (ArtSoft software) 1 05-25-2007 07:51 AM
Confused: Mach Turn, Mach Mill, Mach 2/3 ? CanSir Mach Software (ArtSoft software) 5 02-16-2007 04:41 AM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
Mach 2 Program Question? qsacracer Mach Software (ArtSoft software) 7 11-17-2004 10:39 AM
