Results 1 to 3 of 3
Thread: Z axis
    Sep 2005
    UK
    Z axis
    Hi Everyone, not many posts to my name but i am stuck, stupid thing really but here goes.
    First my build is posted under the CNC PROJECT link on www.foundry-fopars.co.uk.
    So which way is the z axis calibrated??
    do i set 00 at the top ( maximum clearance )or at the bottom (maximum plunge or cut).
    If i set 00 at the top and the spindle drops to cut is the cut a negative number or positive
    i am using Mach3 as a controller
    Mar 2003
    Shelby Twp, MI....USA
    Z=0 is typically set to the top of the workpiece, with cutting depth being negative Z numbers.
    Sep 2005
    UK
    Hi Gerry,
    Thanks so if Z0 is the top of the material being cutwhen the z axiz is home i.e fully retracted, then tih must be a positive number but then how do you ste homing limits if Z0 is neither up or down.
    Everthing else is working and some sample code has been run but i am realy stuck here.
    Roger
  1. A 5-axis CNC machine including a rotary axis
    By synthetiklone in forum CNC Wood Router Project Log
    Last Post: 07-30-2012, 05:43 AM
  2. the Difference of 2-Axis and 3-Axis of Vertical Mill Machine
    By begacon in forum Knee Vertical Mills
    Last Post: 07-30-2009, 07:31 AM
  3. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 03:58 PM
  4. 4-axis, 3+2, or 4+ axis programming system?
    By roboticist in forum General CAM Discussion
    Last Post: 09-04-2006, 02:02 PM
  5. Options for 2 Axis Head (to make 5 axis)
    By drewgarth in forum DIY CNC Router Table Machines
    Last Post: 07-12-2006, 01:37 AM
