| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
I am still very wet behind the ears concerning CNC so I'm hoping this is just something simple I don't know about yet. I recently purchased a converted Sieg Mini Mill from Syil America labeled by them as the X2. The motors they install are Nema 23 stepppers and they drive ball screws. I have set up the machine with the bundled software they provided, including Mach3 and BobCAD/CAM. When opening Mach3 there is a profile provided for the X2 which loads correctly all relevant settings. This made it very simple to get the machine up and running but I ran into something puzzling when I tried to run my first program. When jogging the machine the motors appear to be tuned well and the steps per for all axes is 25400. I wrote a very simple pocket milling program using BobCAD to test with and when I run it the machine does not run smoothly. The end result is still accurate and well finished but the nice smooth motor motion present while jogging is gone. I was not sure what post processor to choose when writing the program so I just randomly selected the Haas post processor in BobCAD and ran with that. The options in BobCAD for post processors are: Anilam 3000M Fadal CNC88 Fanuc 6M(simplified) Haas VF Series HPGL Is this where my error occurs? Is it a motor tuning issue? Is there even an error? Perhaps it is normal for the machine to take audible steps while machining? I apologize if this is a ridiculous question but I didn't find a solution in the training videos, manual, or previous forum posts. Perhaps I haven't looked closely enough. Thanks for reading. -Justin |
| Justin it sounds like you have exact stop mode set instead of cv or constant velocity. There are +- to both but I have found I can live with cv much better than I can with es. Look in the configs page, I think that is where it is located. I might also suggest you go to the mach support site and view the videos there. A world help I assure you. http://www.machsupport.com/ Mike
__________________ No greater love can a man have than this, that he give his life for a friend. |
| If you are in exact mode (proper name escapes me at the moment) then yesit will slow down to near stop at every change of direction.. CV mode(constant velocity) will smooth things out but will round over corners to some extent.. Like everything in life its a trade off... Garry |
| Mike, you were correct in assuming I was in exact stop mode. I changed to constant velocity but my problem persists. Garry, you mentioned that the exact stop mode will almost halt the table at direction changes but the jumpiness of the motors occurs on straight pathways as well. The faster the traverse the more aggressive the bounciness of the motors. i.e. when the z-axis sets up for its initial height (slow traverse) there are audible, tame bounces and when the x and y-axes are moving to the starting position (faster traverse) there are audible, aggressive bounces. I will continue to investigate the problem through the videos, manuals, and trial and error. Thank you both for your responses to my post. |
Garry |
| What Garry is talking about is another program stealing sources that Mach needs. I know one of the things that will zap it is screen savers. Mike
| here are the driver test results. is this bad? should I try and optimize my system? the computer working the machine is a dedicated tower that has no other purpose than to run the CNC so whatever is needed to get this working is ok. any advice? |
| cresusillo, You didn't say what motor speeds your set to or what pc your running. One other possiblility that i have run into is the processor capacity of the pc ! Jogging takes up little proc, in program mode you can create a lot of math for the proc to handle and if the math exceeds the ability of the proc and pipeline etc. then you will have a very nervous system. It could well be much simpler such as the motors tuned too tight or whatever .... just a thought here. I'm waiting impatiently for my package to show up today so that i may upgrade my pc and prove my point. I knew my pc was marginal when i started this then forgot till lately, Good luck with your system and enjoy the Journey !
__________________ Don IH v-3 early model owner |
#10
| cruiser, my motor velocities for x, y, and z are all 60in/min, the accel. for x and y are 6in/s^2 and for z is 0.25in/s^2. the computer is pretty beefy, Intel Core 2 Duo each one running at 1.86GHz, 2GB DDR2 RAM, and a SATA 320GB HDD. Even with a couple of things running in the background it seemed to me that Mach3 should be well taken care of. But these new computers come with about 72 processes running on them standard. I went into msconfig and disabled almost all of the startup processes but that didn't work either. I am prepared to follow the instructions of the optimization file that is posted on the ArtSoft website but it is advised in that same document not to do it unless sure of the problem. So I will bide my time a bit longer and look for other solutions. Thank you for you looking and helping and I hope your problems are solved with your upgraded pc! |
#11
| I thought that my jumpiness to the motors was due to such a horrible driver test result as seen above, but when I changed computer to 'minimal power settings' it almost completely flattened out my driver test results. Being very encouraged by this I tried to run a simple 'g0 x1 y1' command but got the same jerky motion to the point. It sounds like a helicopter. Very frustrating.... if anyone has had similar problems I would love some advice. |
#12
| I see you have steppers, i have servos, i doubt you have geckos for drivers but some clone, i'd look at doc's to see ifn how to tune the motors seeing if they are tuned too tight, per say on my geckos if gain and damp are set to high side then they are tight and jerky also they hum at idle. if i calm the adj down to more neutral then at idle they are silent and when driven they aren't jerky but much smoother. Most likely your best bet is to contact syl america or whoever they are and see what they got for you, as i am truly guessing !
| Fanuc 5T Jumpy? /Bad Backlash | John3 | Fanuc | 2 | 03-18-2007 06:59 PM |
| Servos jumpy n missing steps.... | bigal | Gecko Drives | 8 | 09-29-2006 03:52 PM |
| trying to set up - motors not smooth | t2436jf | Mach Software (ArtSoft software) | 9 | 08-10-2006 04:16 PM |
| smooth motion... | howling60 | CamSoft Products | 11 | 06-08-2006 06:08 AM |
| text not smooth? | DEW | BobCad-Cam | 4 | 04-05-2006 08:20 AM |
