| Machines running Mach Software Discuss your set-up and experiences running your machine using Mach software here. |
| I am new to using Mach 3 and on a "learning curve " It's all working OK on a mill but when I put in the work offset no 1 (G54) and save it - it has not been retained at start up the next day. I have read the manual and set the box on the config screen to persistent offsets. I must be missing something. |
| I have Mach 3 and I reset my G54 offsets every day. When I shut the machine down the next day it's blank when I start up. I used the machine yesterday and as I read your post I went and checked it out and it was clean nothing retained. To many variables to say that your X0Y0Z0 will be in the same place when you shut down and start up again, and if you have stepper motors you have to zero every time as sometimes they want to creep. I only cut wood and I always leave plenty of stock.Maybe it's a good thing it does not retain the G54 you may get lazy and not check and scrap your next part. I downloaded all 154 pages of Mach3 I will read thru and see if there is anything on the subject. Art has a great product going with the the Mach 3, and has great service. 9lrac9 K2cnc owner. |
| G54 Is the default coordinate system, so it doesn't get saved. There's a workaround, however. On the offset screen, click "Save Offsets". Scroll down to the last one, G59P253. Set up your offsets there and save. Open the General Configuration screen. At the bottom right side, check the box that says "copy G54 from G59.253 at startup". Restart Mach3 and you'll have your G54 offsets.
| To have G54 saved you need these settings made: From general config, Axis DRO properties: Optional Offset Save Persistent DROs Above must be selected, all others must NOT be selected, most important unselected is "Copy G54 from G59.253 on startup" if it is selected Mach will allways when started copy work offsets from G59P253. -Mika |
| Gerry / Mika - Many thanks for your comments. I appreciate your help. I tried the configuration as per your suggestion today and it works perfectly ! Thanks again. Geoff |
| Hello, Although this post is old, but still fits my question, so... ![]() This thing with G53, G54 and so on still confuses me. Today i had some problems with milling using G code, generated with solidcam (found postpocessor on this forum). Solidcam added all those codes in the beginning and end of program. I needed to cut out few identical parts. The first one went fine. After that i moved tool back to X0Y0Z20 and then moved to X242Y0Z20, where second part should be cut and then zeroed the X coordinate, regenerated toolpath. But when i started the program, it went to wrong coordinates. Here is the program code:
| N10 and N1740 move the machine to machine coordinate Z0. N15 and N1745 move the machine to machine coordinate X0Y0. You can probably remove these lines if you don't need them. Default coordinate system in Mach3 is G54. Your part is using G55. When you re zero for your second part, you need to make sure you're in G55 when you do that. It's possible your setting the zero in G54. You can use any coordinate system (offset) you want. G54,G55,G66... Each may have a different 0,0,0 origin position. You need to make sure you set your zero position in the same offset your program is using.
| I am totaly knew to this offseting stuff, so don't bite if i sound stupid . Its just that i'm having problems understanding stuff if no samples are provided, not to mention, that its not easy to understand in english, since its not my mother-tongue.So correct me if i am wrong: basicaly, G54-G59 are simply temporary coordinate systems inside main coordinate system? I have found a picture in one book: ![]() And here's how it was explained :
If i understand correct, then G53 command sets my machine coordinate system, which tells me, where my tool is actually on my machine, then G52 sets temporary new coordinate system in program, which will be used as boundaries to work inside (for eg. corner of my stock material). And finally, using G54-G59 i can set temporary coordinate systems inside those boundaries (for eg. several identical parts needed to cut on that stock) right? |
| G53 is the machine coordinates. When you home your machine, it zero's the machine coordinates. G54 is the default coordinate system in Mach3. After you home the machine, you will be in the G54 coordinate system, and any offsets will be applied in reference to the machine coordinates. If your G54 offsets are all zero, then G54 will be the same as G53. G54,G55,G56, ... are all independent coordinate systems, with their offsets relative to the G53 machine coordinates. If you want to have different 0,0 position on your machine, possibly for different fixtures, you can set a specific offset to reference that fixture, and just call that offset before running the part. I once ran a few parts and wanted them 3" apart along the X axis. I set the following offsets: G54 - X0 G55 - X3 G56 - X6 G57 - X9 Run one part, and switch to G55. Run next part, and switch to G56. Run next part, and switch to G57. G52 changes the offsets in the current coordinate system. If you use G52, you need to be careful to reset it so you know where you are.
#10
| Thanks, ger21. Now i think i understand. Gonna make some experimental moves on mach3 without a tool tomorrow. Just one more question from my previous post:
| getting servos to work using Mach 3 | robert johnson | Mentors & Apprentice Locator | 2 | 02-04-2007 10:10 AM |
| work offset in fanuc 6m b- help | rags | Fanuc | 14 | 08-03-2006 09:39 PM |
| how to tell wether or not a driver will work with mach software | derkiow | Mach Software (ArtSoft software) | 4 | 04-13-2006 05:45 PM |
| will my drive work with mach 3 | Fabric8r | Mach Mill | 1 | 02-01-2006 05:46 AM |
| will mach 2 or mach 3 work for 4 axis cnc? | Runner4404spd | Mach Mill | 3 | 10-05-2005 11:44 AM |
